Un produit vendu par http://www.l-c-t.com/ semble tout simplement génial !
Pour l'exemple c'est le modèle pour A3
Prix : même pas 300$ livré !
http://store.l-c-t.com/merchant2/merchant....ategory_Code=A3
- added support for even more different engine configurations and versions
- uses REALSPEED technology to display a more accurate reading in either KMH or MPH
- displays the current Voltage of the Battery - this is helpful to see whether the generator works or not!
- displays the current Oil temperature (where supported) in °C or °F
- display the actual o2-sensor (lambda) readings on the MFD (dashboard) in realtime as a BAR-DISPLAY
- OR display the actual o2-sensor (lambda) readings on the MFD (dashboard) in realtime as a number!
- sampling frequency has been increased for certain sensors to further enhance accuracy
- our Brake Light Assist can now be disabled on the push of a button if necessary
- does not interfere with factory brake light assist if present (so you can use both)
- automatically disables the flashing indicators on reverse if either turn signal is engaged
- allows manual mirror adjustment when mirror is in Parking Assist position
- over 50 other improvements or enhancements of existing functions and features
- display 0-60 mph time on the MFD (dashboard) in realtime
- display 0-90 mph time on the MFD (dashboard) in realtime
- display quarter mile time on the MFD (dashboard) in realtime
- display half mile time on the MFD (dashboard) in realtime
- display 0-100 kmh time on the MFD (dashboard) in realtime*
- display 0-140 kmh time on the MFD (dashboard) in realtime*
- display 400 metre time on the MFD (dashboard) in realtime*
- display 800 metre time on the MFD (dashboard) in realtime*
- uses REALSPEED technology to calculate 0-60/0-90 (0-100/0-140) times where supported
- display two independent data feeds at a time - choose which one to show
- new approach for time measuring, now easier to use with stick shift models
- display the turbo boost pressure on 2.0t and TDI engines on the MFD (dashboard)
- added initial support for S3 configuration
- change between absolute or relative pressure display for current or max boost
- change between KPA, PSI or BAR
- display the current calculated torque in NM or lb-ft on the MFD
- display the current RPM digitally on the MFD
- display the calculated HP on the MFD
- allowing to select between 2-6 comfort blinks (factory is only OFF or 3) on either indicator
- adding a special indicator or horn sequence while you are in reverse gear
- improved error handling with certain configurations (could be observed mainly on European models)
- adding Brake Light Assist
- adding Mirror Park Assist (flips down the passenger side mirror so you can see the curb)
- new temporary mirror park assist disable (on/off at the push of a button)
- allows 2 different ways to configure the comfort functions (especially of interest to European customers!!)
- functions can be configured through our exclusive on dash menu via the MFD
- added support for a variety of aftermarket radio adapters (in case the factory radio has been replaced)
- ships now with all configurable comfort functions disabled by default
- easy installation - takes less than 15 minutes
- new installation harness for full plug and play: no wires to cut or splice!
- dual core processing power
- 90 days limited warranty
- PATENT PENDING
Moins de 5 min pour l'installer .... produit miracle ?
Y aurait il quelqu'un pour tester ?
Pour ma part, il n'est pas disponible pour S3 (véhicule non répandu aux states ... :( ) et la version TT est Out Of Stock !
J'ai donc mailé le vendeur concernant une possible compatibilité TT/S3 :
the TT module will only work with the TT (that is why it is advertised for the TT only). As for the A3 vcm on the 1.8T, i would say it will not work ok with your simply because i have no reference here from engineering that it has been tested successfully on this engine and model year.
Etant donné qu'ils ne connaissent pas vraiment le S3, je me demande si la version TT serait pas compatible :P
Ici un exemple de montage sur LEON
http://store.l-c-t.com/merchant2/merchant....e=LEON_INTERIOR
Des avis ? Des motivés ?
Modifié par Ptisik
Et bien, il ne faut pas se louper en appuyant sur le commodo, sinon vous êtes bon pour faire un tour complet !!!!!
Très interessant, surtoutsi je peux récupérer le totaliseur kilométrique journalier, comme les B7 récentes....
Je connais ce principe, appelé FIS plus....Un peu cher leur produit....Toutes ces fonctions étant plus ou moins présentes quelque part....
y a pas quelqu'un qui expliquer se produit en français :rolleyes: no speak english ...
Tu le branches en dessous de ton tableau de bord (c'est comme un branhcement en T) et ca te permets d'avoir un ODB ultra complet qui te donne toutes les infos de la voiture + des trucs comme la vitesse instantanée, le 0 à 100, la pression turbo, d'air...enfin pleins de truc quoi. Mais ils sont en rupture de stock pour la A3.
salut.
vu le nombre d'info a récupérer, ça m'étonnerait qu'il faille 5 mn pour l'installer.
C'est un boitier qui se branche sous ton tableau de bord, c'est lui qui analyse les données qui sont de toute façon envoyées à ton ordinateur mais qui ne sont pas affichés d'origine. Une lampe et une machine à laver n'ont pas la même puissance quoique parfois...mais bon elles se branchent aussi facilement l'une que l'autre :bigsmile: Mais ils sont en rupture depuis juillet :( je sais pas quand je pourrais récupérer ca
Modifié par napalm02
