Es-que vous pouvez me guidé je c'est pas ce qu'il ne va pas .
voyant abs ou esp plus les voyany prnds en rouge par intermittence
voici les logs
Thursday,04,June,2015,00:06:16:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8E25A542233 License Plate:
Mileage: 158140km-98263mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E25A542233 Mileage: 158140km/98263miles
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: 00000001 Serial number: 0000999
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: E4CD34D027A5FE3E90B-80B1
3 Faults Found:
18291 - Park/Neutral Switch
P1883 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 99
Reset counter: 40
Mileage: 153702 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 864 /min
RPM: 800 /min
RPM: 512 /min
(no units): 3.0
(no units): 20.0
Temperature: 76.0°C
T.B. Angle: 0.0°
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 18
Reset counter: 40
Mileage: 153951 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 40
Mileage: 158131 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004426
Shop #: WSC 06314 000 00000
VCID: 2757E3DC9613D526F59-8072
2 Faults Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 10101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x3200
Hex Value: 0x4004
Hex Value: 0x00FF
Hex Value: 0xFFAC
Hex Value: 0x00FF
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 38
Time Indication: 0
Freeze Frame:
Hex Value: 0x3600
Hex Value: 0x4206
Hex Value: 0x00FF
Hex Value: 0xFFAE
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
VCID: 6BDFDFEC197B3146511-5000
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0503
Coding: 01031
Shop #: WSC 04743
VCID: 397335A423A753D693D-4A3A
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M003SH4/
Coding: 0033622
VCID: 3B7F2FAC7A9B61C6811-806E
Subsystem 1 - Serial number: 6332DRB401624D1DN
Subsystem 2 - Serial number: 6342DRB40163902CH
Subsystem 3 - Serial number: 6352ARB4004F1642E
Subsystem 4 - Serial number: 6362ARB4004F1A71L
Subsystem 5 - Serial number: 63729RB40056D497R
Subsystem 6 - Serial number: 63829RB40056D4F3U
3 Faults Found:
00590 - Igniter 2 for Passenger Airbag (N132)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 16
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: LenksĂĄulenmodul 0601
Coding: 04141
Shop #: WSC 06314
VCID: 41835D444B770B16DBD-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007141
Shop #: WSC 00001 001 66865
VCID: 336F078C51CBA986591-5072
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007141
VCID: 336F078C51CBA986591-5000
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: KomfortgerĂĄt T23 3232
Coding: 06768
Shop #: WSC 06314
VCID: 820112488EF1500E027-4A3A
Subsystem 1 - Part No: 8E1959801F
Component: TÔrsteuer.FS BRM 1315
Subsystem 2 - Part No: 8E1959802E
Component: TÔrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: TÔrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: TÔrsteuer.HR BRM 0205
1 Fault Found:
00955 - Key 1
35-10 - - - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Coding: 0000005
VCID: 397335A470A753D693D-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 36
Time Indication: 0
Address 77: Telephone Labels: None
VCID: 55AB9914BFFF97B6975-5000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End ---------------------------------------------------------------------
Je m'excuse de l'orthographe. J'ai l'impression que mon traducteur y est pour quelque chose.
ce soir le bestio a démarrer avec les meme voyant qu'au debut .donc je coup le contact je débranche la batterie et vérifie tous les fusible .coté calculateur abs (a coté de la batterie) rien a déclarer
ensuite sous le volant rien a déclarer sur les fusible visible .les gros fusible noir je ne les est pas tésté . réset code au vagcom
mes rien y fait elle ne veux démarrer elle cale au bouts de 2 seconde
dernier log
Thursday,04,June,2015,18:06:07:65217
67 69 75 76 77
Coding: 00000
Shop #: WSC 00000
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
79-00 - Please Check Fault Codes
Coding: 01031
Shop #: WSC 04743
Coding: 04141
Shop #: WSC 06314
Coding: 0007141
5 Faults Found:
01315 - Transmission Control Module
01321 - Control Module for Airbags (J234)
01771 - Control Module for Headlight Range (J431)
014 - Defective
Coding: 0007141
5 Faults Found:
014 - Defective
Coding: 06768
Shop #: WSC 06314
No Faults Found
Thursday,04,June,2015,18:25:51:65217
67 69 75 76 77
Coding: 00000
Shop #: WSC 00000
Coding: 01031
Shop #: WSC 04743
Coding: 04141
Shop #: WSC 06314
Coding: 0007141
1 Fault Found:
014 - Defective
Coding: 0007141
1 Fault Found:
Coding: 06768
Shop #: WSC 06314
VCID: 55AB9914BFFF97B6975-5072
No Faults Found
La seul chose que j'ai trouvĂ© anormale c'est 3 fils qui son relier a la prise du calculateur sous le volant (au fond a gauche) qui sont dĂ©connecter . sauf que de l'autre cotĂ© les fils son coupĂ© sur la prise .le problĂšme mais arriver en roulant .sa m’entonnerais que les fils ce son coupĂ© tous seul.
autre analyse le voyant sur la boite pour appuyer sur la pédale de freins n'est plus rouge .
Il a fait 40 degré j'en peux plus .
Je crois que tu as un sérieux problÚme de calculateur moteur. Comme il ne répond plus, l'Immotronic n'autorise plus l'allumage des injecteurs, et donc la voiture cale. Comme ce n'est pas le bloc compteur qui est en défaut ici, il te faut te pencher du cÎté du calculateur moteur. Il se situe tout à droite dans un boitier plastique étanche, sous les essuie-glaces, lorsque tu es face au moteur.
:coucou:
oui bonne idée léon.
normalement il est étanche mais ça peut arriver que de l'eau arrive à se faufiler si jamais le cache étanche à été ouvert et mal remonté...
J'ai précisément chercher dans ce coin là tous les fusible autour son bon. Qu'es que je peux faire sur le calculateur. L'ouvrir y a t'il pas un risque. Ci je dois changer le calculateur ya t'il une procédure. Je pense l'amener chez Audi.
SI tu l'emmÚnes chez Audi, prévois un gros chÚque !! Il me semble que le calculateur seul coute dans les 800 ou 1000 euros. Ensuite il faudra le programmer à ta voiture, donc encore quelques centaines d'euros.
Essaie de prendre contact avec des entreprises de réparation de calculateurs automobiles, car perdu pour perdu, ça se tente !
Bon courage en tout cas, car c'est étrange si c'est lui qui a claqué. Il n'aura pas forcément pris l'eau ou un coup de chaud, mais tu n'en es plus à savoir ce qui s'est passé, mais plutÎt comment faire redémarrer ta voiture. D'ailleurs, quelle motorisation ?
Il se peut que ce soit un composant qui ait claqué, auquel cas tu devrais t'en tirer pour "pas trop cher" ... N'hésite pas à faire des devis, et garde bien tes logs de VAG COM. Et si par chance ta voiture est reprog et que tu as à disposition le soft d'origine, ça devrait pas trop mal se passer ...
:coucou:
C'est un 3.0 tdi quattro triptronic 2005 204. J'Ă©tais en train de rĂ©flĂ©chir pour la faire reprogrammer. Mes trop tard. Es que c'est une bonne idĂ©e de faire le diagnostic par Audi et ci c'est le calculateur le faire par une sociĂ©tĂ© spĂ©cialisĂ©e. A part un coup de chaud je ne vois pas. C'est vrais qu'il y a 10000 km En arriĂšre j'ai u deux fois le mĂȘme fusible qui a cramĂ© prĂšs du calculateur.
Un diag chez Audi ressortira la mĂȘme chose que tes logs ...
:coucou:
Je les amené chez un pro. Ci il fait du bon boulot je ferais de la pub. Ce qu'il paraßt c'est un ancien de chez Audi.
  • CrĂ©er...
