Tout ce qui a été posté par geoffroy 67
Mon Audi A4 S-Line Grey and Black
geoffroy 67 a répondu à un(e) sujet de Madingwada dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
exactement tu dois le rencoder pour une A4..... dans module navigation ou radio Coding 0?xxxxx: Model 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) [*]0x?xxxx: Treble Speaker Monitoring inactive 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet) 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet) [*]0xx?xxx: Sound Characteristic 0 = Sound Characteristic linear 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sound System [*]0xxx?xx: Telephone/Telematic 1 = Telephone not installed (Remote Feed Voltage for Microphone active) 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive) 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive) 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive) 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive) 6 = Telematic US (Remote Feed Voltage for Microphone inactive) 7 = Base Plate diagnostic capable with Comfort Control [*]0xxxx?x: Equipment I 1 = Tuner not installed 2 = Digital-Radio installed 3 = Satellite-Radio installed 4 = Satellite and Digital-Radio installed 5 = Analog Input (AUX) installed 7 = Satellite-Radio & Analog Input (AUX) installed [*]0xxxxx?: Equipment II 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed 2 = TV-Tuner installed 3 = CD-Changer installed 4 = TV-Tuner and CD-Changer installed 5 = Multi-Function Steering Wheel installed 6 = TV-Tuner and Multi-Function Steering Wheel installed 7 = CD-Changer and Multi-Function Steering Wheel installed 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed -
a part avoir coder son RNSE pour une A3 je vois pas :unsure: meme si tu rencode le RNSE pour une A3 il ne s'allume et s'eteint plus avec le contact et l'eclairage des touche non plus ne fonctionne plus.. deoler pour le HS madingwada -
:( :hot: :hot: -
si j'ai les boutons chromer :biere::biere: :bigsmile: -
moi j'ai un 193 avec DVD 2011 et 2012 et pas d'affichage vitesse limite sur le RNSE... avec agassy on cherche comment l'avoir dans la rubrique RNSE donc si quelqu'un sais comment faire je suis preneur :bigsmile: :coucou: -
oui j'ai tout activer/rencoder.... c'est vraiment top le RNSE et encore plus le 193 :eldiablo: :eldiablo: :eldiablo: -
Ampoules Philips X-Treme Power H7
geoffroy 67 a répondu à un(e) sujet de smartgeek dans A4 B6 / A4 B6 Cabriolet - (2001 à 2004)
non zero defaut pourtant j'ai un kit a 50 euros et ca marche nickel depuis 1 ans j'hesite a passer en 55W.... :eldiablo: :eldiablo: :eldiablo: -
Voilà mon A4 Avant (B6) !
geoffroy 67 a répondu à un(e) sujet de dr_bidine dans A4 B6 / A4 B6 Cabriolet - (2001 à 2004)
pour remplacer l'ecran de demarrage tu va dans module nav -> adaptation -> canal 18 et tu choisi Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding. 0 = Standard Start Screen 1 = Audi S3 Start Screen 2 = Audi S4 Start Screen 3 = Audi RS4 Start Screen 4 = Audi TT Start Screen 5 = Audi R8 Start Screen :coucou: le volant 3 branches tu la touché a combien avec l'airbag? -
salut .... nous faut des photos :bigsmile: :bigsmile: :bigsmile: :bigsmile: sinon pour rencoder ton RNSE pour ton A4 en tout premier tu dois rencoder le module (17) instrument -> va dans adaptation -> choisi canal 62 -> et la tu rajoute +4 a ta valeur existante (tu devrais avoir 21 apres le changement) cette manip est pour faire reconnaitre le RNSE a ton A4 et activer la navigation dans le SIC ensuite tu va dans le module navigation (37) ou radio (56) peu importe l'un rencode automatiquement l'autre et tu rencode en fonction de tes options Coding 0?xxxxx: Model 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) [*]0x?xxxx: Treble Speaker Monitoring inactive 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet) 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet) [*]0xx?xxx: Sound Characteristic 0 = Sound Characteristic linear 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sound System [*]0xxx?xx: Telephone/Telematic 1 = Telephone not installed (Remote Feed Voltage for Microphone active) 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive) 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive) 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive) 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive) 6 = Telematic US (Remote Feed Voltage for Microphone inactive) 7 = Base Plate diagnostic capable with Comfort Control [*]0xxxx?x: Equipment I 1 = Tuner not installed 2 = Digital-Radio installed 3 = Satellite-Radio installed 4 = Satellite and Digital-Radio installed 5 = Analog Input (AUX) installed 7 = Satellite-Radio & Analog Input (AUX) installed [*]0xxxxx?: Equipment II 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed 2 = TV-Tuner installed 3 = CD-Changer installed 4 = TV-Tuner and CD-Changer installed 5 = Multi-Function Steering Wheel installed 6 = TV-Tuner and Multi-Function Steering Wheel installed 7 = CD-Changer and Multi-Function Steering Wheel installed 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed et pour terminer tu va dans adaptation, toujours module nav ou radio et tu choisit canal 2 et la tu met 45 (pour A4 8E) et sur le canal 1 qui est pour la circonference des roues tu met 1967 (pour du 235/40/18) pour remplacer l'ecran de demarrage tu va dans module nav -> adaptation -> canal 18 et tu choisi :coucou: -
t trop gentil ... effectivement une recherche aurait ete la bienvenue
salut ceux qu'il te faut ICI prix 400 € :coucou:
coques rétros S4 b7
geoffroy 67 a répondu à un(e) sujet de ttstock58 dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
les coques de retro aluminium ref: 8E0 857 507 D 3Q7 coté gauche 238€ 8E0 857 508 D 3Q7 coté droit 238€ references audi avec prix audi :coucou: -
ton porte monnaie ne va pas m'aimer mais c'est tellement bon... moi j'ai monter un 193 il y as 1 mois.... :malelovies: -
sur nos B6 c'est du H7 code et phare oui tes ampoule on l'air bien... mais rien ne vaut un kit HID.... j'en monte toujours sur mes voiture et suffit de bien regler tes feux et tu n'eblouie personne..... :coucou: -
ma nouvelle audi A4 3L V6 S-line (présentation)
geoffroy 67 a répondu à un(e) sujet de a4tdi2l dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
:jap: :jap: :jap: -
:bigthumbup:
ah ok... :bigsmile: en tout cas en pneus hivers il sont top. maintenant en pneu été je ne sais pas ...
Besoin de votre aide pour passage en RNS-E
geoffroy 67 a répondu à un(e) sujet de Goodwood dans GPS RNS-E
belle modif j'ai vue ton post :bigthumbup: moi j'ai aussi monter un RNSE mais un 193 et maintenant j'hesite a prendre le BT...... si vous avez un bon plan je suis preneur :bigsmile: :bigsmile: -
"booktype" c'est quoi? j'ai deja le DVD 2012 mais j'aimerais faire une sauvegarde... t'as utiliser quoi comme graveur c'est juste pour faire une copie personnel
Ma 3.0 TDI ...
geoffroy 67 a répondu à un(e) sujet de cyril1989 dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
sympa tout ca :bigthumbup: :bigthumbup: :bigthumbup: -
pas de probleme de plus tu peux utiliser une douille pour l'ouvrir.... je sais plus exactement mais je dirais une douille de 24 :coucou: -
regarde la photo pour ta coche du filtre a huile -
met une photo de ton moteur pour que je vois exactement je dis pas que t un boulet mais la ca me parait bizzare que la cloche est derriere l'echangeur -
t sur d'etre sur la clache du filtre a huile la??? :blink: -
j'ai les nokian G2 comme pneus neige depuis l'année derniere.... j'en avais de differente marque... et je peu te dire que les nokian dans la neige sont top....... mais ils ont bien augmenter leur prix..... en tout cas ils sont mieux que les michelin alpin :bigthumbup:
