look calandre passat et feux Ar de Golf plus ( trés moche d'ailleurs en vrai ... furious.gif )
157160[/snapback]
soit dit en passant, les feux arrières sont des leds... qu'on le veuille ou non, c'est le futur et à terme, les véhicules en seront tous équipés.
Perso, je trouve cela très beau. Ca me rappelle aussi une option sur la nouvelle A6 comprenant un pack éclairage composés de leds, le top en matière d'éclairage mais le prix de cette option sur l'A6 est aussi au top.
Modifié par Mitch
OK, mais ils peuvent étre à LEDS ET beaux.
Là, ce n'est pas le cas...
157180[/snapback]
tu me parait bien difficile...
je ne partage pas ton avis mais bon, je respecte ton opinion...
les goûts et les couleurs...
user posted image
user posted image
user posted image
The combination rear lamps on the new Golf Plus have a two-part design. When switched off, four brilliant-white circles on a red base can be seen. The tail light, stop light and direction indicator are positioned at the respective outside edge of the vehicle. 36 LEDs per side serve as the light sources. For the tail light, all 72 LEDs emit red light. When the driver applies the brake, the two sets of 16 LEDs in the two inner circles light up with increased intensity and, together with the third stop lamp in the roof-edge spoiler (which also uses LED technology), form the now classic optical "warning triangle". When the driver switches on the direction indicator, the respective set of 20 LEDs in the outer lamp rings are activated and emit the prescribed amber light. This even works with the tail light switched on, since the LEDs have a two-colour design and the flashing amber colour outshines the red of the tail light. LEDs have safety-related advantages, particularly with regard to the stop light and the direction indicator: LEDs react much more quickly than conventional filament bulbs. Traffic following the vehicle is therefore warned earlier. A further advantage is the homogeneity of the illuminated areas. Thanks to the use of diodes, the functional areas can be implemented completely with a brilliant look for the first time, without coloured intermediate lenses being necessary. The reversing light and rear fog light still use conventional filament bulbs as light sources, since this technology is most suitable for these functions.
Among the advantages cited for LEDs for front lighting are:
Long life: Longer than the vehicle life
Different colors: The chip can produce red, yellow or white light
Low infrared emissions: This permits the use of plastic optics, which means that shapes can be produced that can't otherwise be attained
Low power consumption: On the order of 15 to 20 W when used as daytime running lights, for example
Electronic compatibility: Compatible with the increasing number of on-board electronics, and capable of doing things (e.g., switching from low beam to high or vice versa) faster than conventional bulbs.
Modifié par Mitch
157180[/snapback]
Je la trouve mieux de face. Les feux arrières ne sontpas mal non plus.
En fait, et tes photos me confortent dans mon idée, je les trouve beau allumés !
Modifié par tom59
Peut-on parler de lifting..... en fait, c'est simplement une amélioration de l'equipement, avec généralisation du PC de la GTI.... remplacez le plastoc noir par du chrome et hop l'affaire est dans le sac biggthumpup.gif
Pour l'arriere, pareil...... le passage aux leds, s'il est bienvenue bien.gif n'est qu'un petit détail quand meme........ pas de modif formelle, pas de nouveau moule....
Apres, pour ce qui est du lokk, les leds c'est top, en revanche, je ne vois pas l'intéret de creer un tel contraste, en faisant ressortir les cercles" par le choix de la couleur blanche...... monochrome rouge c'eut été plus subtil, et pas moins joli a mon gout...
Il suffit de voir les dernieres séries 3 coupé de la génération actuelle, c'est du led, c'est monochrome.... et ca pete ! Pareil sur la toute derniere A6 Avant d'ailleurs lover.gif
Modifié par ypos
157302[/snapback]
t'es un type bien, Tom59... tu écoutes les autres.
m'étonnes pas pour un gars de Lille.
mais va savoir, la législation va peut-être changer et rendre l'allumage des feux obligatoire de jour, n'en déplaise aux motards (que je comprends car j'en fais partie).
157180[/snapback]
Il ne faut pas généralisé, car ça plait ou ca ne plait pas.
Ce "mini" restylage sera le bienvenue dans une dixene de mois je pense, pour mettre le nouveau signe distingtif des VW sur la star des ventes.
user posted image
Modifié par ypos
157776[/snapback]
... tout comme l'A3.
Pour en revenir au sujet, je trouve les feux géniaux quand ils sont allumés, un peu moins quand ils sont éteints.
Je pense que la couleur de la voiture y est pour quelque chose.Toujoues est il que sur la passat que j'ai croisé dernièrement, je n'aimais pas.... et sur la golf + noir magic, je trouvais plutôt joli.
158510[/snapback]
Avant ce lifting, la Golf va subir quelques modifications dès maintenant, avec amélioration de certaines présentations intérieures (couleurs, etc.) et d'équipements (disponibilité du GPS DVD). Tout cela est officiel - voir le configurateur sur volkswagen.de. Evidemment, il va falloir attendrfe juillet pour l'avoir en France je suppose bleble.gif
