jacquouR
    1
Tout ce qui a été posté par jacquouR
  1. Oui, c'est très important: Toute courbure excessive de la fibre optique peut provoquer une réfraction du signal optique et des fuites à travers la gaine. Pour un câble non chargé en traction, le rayon de courbure minimum correspond à 10 fois le diamètre extérieur.
  2. La liste des équipements et options: E0A No special edition 7MG Emission standard EU5 4UF Driver's and front passenger air bag with front passenger air bag deactivation 6XK Exterior mirrors: automatically dimming,electrically foldable/adjustable/heated 5SL Left exterior mirror: aspherical 5RU Right exterior mirror: convex (large viewing field) 1KD Disc brakes, rear J0Z Battery 520 A (110 Ah) 1LG Disc brakes, front 1X0 Front wheel drive 1BA Standard suspension/shock absorption 3FE Electric slide/tilt sunroof with sun screen/sunblind 7TL Decorative inserts 7X4 Park distance control, front and rear 4R4 Power windows with comfort operation andcircuit breaker F0A No special purpose vehicle, standard equipment 8GV Alternator 180 A 0G1 Gearshift lever 0YG Weight range 7 installation control only, no requirement forecast 0JL Weight category front axle weight range 11 TA1 6-cylinder diesel engine 2.7 L unit 059.F 3NZ Rear seat bench unsplit, backrest split folding 8BD Halogen headlight U1A Instrument insert with km/h speedometer,clock, tachometer and trip odometer X3A National sales program France 1N3 Speed-related variable steering assist (Servotronic) 2ZQ Leather trimmed multi-function steering wheel for air bag system 8Q1 Headlight-range adjustment 9Q4 Multi-function display/on-board computerwith check control 8Z5 Not hot country D4V 6-cyl. turbo dies. eng. 2.7 L/140 kW 24VV6 TDI, common rail base engine is TA1/TH1 7T2 Navigation system (LOW) C9X Alloy wheels 7.5J x 17 7K0 Without tire pressure warning light 4X3 Side air bag front with curtain air bag 2K1 Reinforced bumpers 3L3 Manual height adjustment for front seats 4KC Side and rear windows in heat-insulatingglass 3Y0 Without roll-up sun screen 4K4 Radio remote controlled central locking 5D7 Carrier frequency 868 MHz without panic button 1SA Without additional front underbody guard Q1A Standard front seats 4GP Windshield in heat-insulating glass withsunshield and viewing window for vehicle identification number
  3. Donc, pas de problèmes pour reconnaître un Iphone par le MMI?
  4. :bien:
  5. C6!
  6. Au début, quand j'ai acheté la voiture, je croyais que le bluetooth n'était pas inclus. En fin de compte, avec un ami qui avait le vagcom, le bluetooth existait et a été réactivé. J'ai un MMI 3G Basic. Je pense que, quand la voiture a été rendue à la concession (fin de LDD), il y a eu un nettoyage des données + d'autres manipulations... Donc à vérifier avant de mettre une autre installation. Cela dit, j'ai un Windows Phone Nokia, je suis hors sujet par rapport à un Iphone. Par contre, je me pose la question pour Iphone, est-ce compatible au cas j'en achèterai un? Ma configuration Bluetooth: 4.3.0/4.3G1.138.3
  7. Essaie, sur les sites allemands via e-bay, la différence de prix est parfois conséquente. En occasion, 200 €.
  8. Au bout de combien de temps et de kms, cette courroie de distribution?
  9. J'adore cette A8 qui fait vraiment classe :agenoux: .
  10. Oui, mais avant la version Avus n'existait pas, c'était l'Ambition Luxe en haut gemme. Audi a recentré la version Ambition Luxe dans le millieu de gamme, suite au rajout de la version Avus qui est devenue le haut de gamme standard. Donc, certains équipements ont été abandonnés sur Ambition Luxe à l'avantage de Avus. Regarde plus haut le post de jackson-ms qui est très clair à ce sujet.
  11. Pour ma part, j'avais laissé une glacière électrique dans le coffre, branchée toute une nuit. Au matin, des voyants étaient allumés, pour certains en défaut, comme si j'avais des pannes. Impossible d'ouvrir le coffre! Il devait rester un peu de jus dans la batterie et donc la clé en position tournée vers la gauche pour la portière conducteur et patience (c'est le seul endroit pour la clé), ça s'ouvre au bout de quelques instants. Ensuite, je me dépanne avec une autre batterie et ça repart. Une glacière, 46 Watts sous 12 VDC pendant une nuit, pas besoin de faire un dessin :icon8: . Donc, tiens nous informé, à savoir si ce n'est pas ta batterie qui s'est déchargée ou elle a un défaut.
  12. Vers fin 2016, le lecteur de CD/DVD pour la cartographie donnait des faiblesses (interruptions momentanées de plus en plus répétitives), j'ai copié les données du CD/DVD vers un lecteur SD comme j'ai 2 lecteurs en dessous de celui-ci. Sur le livret d'utilisation du MMI, j'ai remarqué que c'était proposé. J'ai lancé l'action et j'ai eu beaucoup d'échecs de transfert et j'ai persisté autant de fois qu'il se peut pour enfin réussir au transfert des données. L'avantage du SD est toute façon indéniable car la lecture n'engendre pas d'usure hormis la fiabilité de la carte électronique. Ensuite, il faut retirer le CD pour que seul le support SD prenne le relais. On entend plus ce frottement sur le lecteur CD/DVD qui devait présenter des défauts à la longue. Toutefois, j'ai réussi entre-temps à nettoyer la tête du lecteur avec un CD de nettoyage et ça fonctionne. En tout cas, pour ce modèle de véhicule, il faut éviter d'utiliser le lecteur CD/DVD sauf pour la mise à jour et n'utiliser que le support SD bien plus fiable et plus rapide, après avoir copier les données de navigation sur celui-ci.
  13. Oui et si ça peut aider. Il y a ce site aussi pour les catalogues: http://laurent.bunnik.archives-catalogues-automobiles.fr/auda6301.html Pour ma part, j'ai archivé le mien à partir d'un autre site, mais le lien n'existe plus.
  14. J'adore cette discussion! :bravo: :humour: Mais, ça m'a bien occupé... :tourne: et j'ai quand même appris des choses...
  15. Pour les options, j'ai: 3FE: Toit ouvrant électrique coulissant et relevable en verre, pare-soleil réglable en continu. 7TL: Applications de frêne veiné brun naturel sur le tableau de bord, les contre-portes et la console centrale. 7X4: Parking System Plus : signal acoustique et visuel d’aide au stationnement avant et arrière par pictogrammes sur l’écran couleur du MMI. LX5Y: Peinture métallisée OK
  16. Pas en 2009, la finition Ambition n'existait pas. Il y avait: Ambiente, S line, Ambition Luxe, Avus.
  17. Tu veux dire Ambiente. Pour faire simple sur la mienne qui est une Ambition Luxe, j'ai: Jantes en aluminium forgé style 7 branches structurées, 7,5 J x 17’’, avec pneus 225/50 R 17 Applications décoratives en ronce de noyer brun sur tableau de bord, contre-portes et console centrale Rétroviseurs extérieurs escamotables électriquement Sellerie, appuie-tête et accoudoir central avant en cuir Milano
  18. Ci-après les détails des équipements complémentaires de série :
  19. Ce qui est indiqué dans le catalogue, équipement de série: Sièges avant avec réglage manuel de la hauteur, de la longueur et des appuie-tête, ainsi que réglage de l‘inclinaison du dossier. Sur la version Avus, équipement complémentaire: Sièges avant à réglage électrique.
  20. Voilà :winner: Phase 1 : 2004-2008 Phase 2: octobre 2008-2011 La mienne étant de 05/2009, c'est forcément une phase 2
  21. C'est forcément une phase 2 d'autant que sur le catalogue, c'est marqué "Nouvelle Audi A6".
  22. Les différentes causes de mortalité en France en 2016: http://www.lecurionaute.fr/mortalite-de-quoi-meurt-on-en-france-en-2016/
