winblows
Tout ce qui a été posté par winblows
  1. il faut faire un downgrade et pour cela passer par le vag-com -> Channel 097 (Downgrade Software) 0 - Normal operation, unit performs updates only 1 - Force downgrade to older version, requires older DVD/CD
  2. winblows
    Firmware
    essaie de nettoyer la lentille car moi tout fonctionné sauf le dvd de navigation.
  3. winblows
    commandes vocales sur RNS-e
    il etait bien preciser au debut du post que c'etait pour ajouter la commande vocale sans le kit bluetooth donc avec ce kit les branchement sont differents "As far as I can guess, it is to take the + and - from the mic (witch now is connected at + and - to the BT module) and connect this to the MIC input + and - in the RNS-e. Then, use a cable to connect the + and - from RNSe MIC output + and - , to the BT module + and - MIC input." RNS-E Connector C 1 - from Mic - in car 4 - to BT pin 11 7 - from Mic + in car 10 - to BT pin 12 et apres modifier le codage du module bluetooh In order to use SDS in RNS-E, the BT module must be re-coded to xxxxx0x or xxxxxx8x (both seems to work) A working MIC wiring is simply to connect the MIC to BOTH the RNS-E and the BT-module (in parralell). Pin numbers are listed in previous posts. Be sure to use shielded cables and mind the +/- (- is shield). When you install the MIC remember that most cars has it pre-wired down to the left pillar, behind the plastic cover just beside the footrest toutes ces infos viennent du forum http://audiforum.us/ le post en question http://audiforum.us/rns-e/5310-re-wiring-sds.html
  4. juste comme ça en passant pour la prise bleue de l'ampli 1 - Line input - right rear, from Radio 2 - Line input Ground, from Radio 3 - Line input - left rear, from Radio 9 - Switched positive from Radio 14 - Bass Loudspeaker R100 ( + ) 15 - Bass Loudspeaker R100 ( - ) 17 - Left rear loudspeaker ( + ) 18 - Left rear loudspeaker ( - ) 20 - Right rear loudspeaker ( + ) 21 - Right rear loudspeaker ( - ) 22 - Ground (GND) Terminal 31 23 - Battery positive (B+) Terminal 30
  5. un repertoire (dossier)avec une playlist (extension m3u) dans chaque dossier ,rien de plus simple.De plus il existe un tas de logiciel pour creer des playlists
  6. voila,je voudrais juste savoir si les menus sont en francais (du genre memoire au lieu de memory,reglages au lieu de set up) ou peut etre est-ce configurable (multilangage)
  7. oui moi aussi pour la radio j'ai des lettres bizarre,sujet souvent traité et la reponse d'audi serait qu'ils ne peuvent rien faire. faire un downgrade ne te servirait a rien.trouve toi un 2008 fonctionnelle ou 2009 cela te couteras moins cher que de faire un downgrade chez audi (90 euros a peu pres pour un coup de valise)
  8. je ne peux pas te l'affirmer ni le confirmer,j'ai resonné par deduction.C'est a dire qu'on suppose que tu veuilles installé un RNS-e en remplacement de ton RNS-d dans ce cas l'adaptateur Kufatec.Apres on part du principe que tu veuilles changer ton RNS-E (virtuel) par un autoradio standart,dans ce cas l'adaptateur de carteq est fait pour cela.Maintenant si tu envoie un mail a kufatec et un mail a carteq (pour leur demander a quoi sert le fil bleu,par exemple). je ne peux pas faire mieux dans mes explications un petit dessin en plus
  9. ou bien trouver une copie 2009 qui fonctionne car une copie "mal faite" uniquement la mise a jour logiciel fonctionne
  10. il me semble que tous les details,infos sont là donc a toi de "jouer"
  11. quand on regarde la piece 14,il s'agit bien d'un ampli pour l'antenne diversity donc si lui n'est pas connecté,ben la reception ne peut etre que mauvaise +12v remote ou antenne electrique c'est la meme chose disons que c'est surement un +12v apres contact :rolleyes:
  12. j'ai edité je pense a un +12v d'antenne electrique
  13. si le diversity est obligatoire car les antennes de vitres sont reliées entre elles via le systeme diversity le mieux est d'envoyé un mail a Kufatek,ils font les cables et adaptateur a la demande si il n'existe pas .peut etre qu'il existe sur cette page. donc tu leur dis bien que tu passes de tel poste a tel poste..... sinon au pire tu choisis cette adaptateur et apres tu connectes celui-ci pour le fil bleu je pense que c'est un +12v antenne electrique mais a confirmer si tu achetes l'adaptateur chez eux sur cette photo (ce n'est pas une A6 ni pour un rns-d)mais je pense qu'il y a peu de difference mais on voit bien l'utilité de brancher les 2 cables
  14. et toi tu as utilisé uniquemet le gros du milieu (prise antenne classique,je suppose car il semblerait que sur le RNS-d il a y 2 cable a branché pour la FM (celon modele apparemment)donc si le 2eme n'est pas branché,peut-etre la cause de ta mauvaise reception.Te souviens-tu lors du demontage si tu avais les 2 cables branchés ?
  15. sur ton RNS-D tu n'as pas ce type de connection ????
  16. dans ce cas cela devrais fonctionner avec cette adptateur http://www.carteq.fr/prise-adaptateur-ante...agen-skoda.html
  17. je ne sais pas quel type de vehicule tu as ni non plus comment tu as brancher ton antenne (adaptateur ???) mais pour utiliser les antennes d'origines il me semble que cela devrait faire l'affaire http://www.carteq.fr/prise-adaptateur-ante...agen-skoda.html ou http://www.carteq.fr/prise-adaptateur-ante...agen-skoda.html
  18. Voila,Mon RNS-E après 20 mois de service a décidé qu'il était temps de m'embêter un peu donc lecture DVD impossible. Au debut cela arrivait après un certain temps,puis de plus en plus souvent et lors du retrait du dvd de navigation il était très chaud.Je passe l'étape ou j'avais nettoyé la lentille avec un cd special+nettoyage au coton tige de la lentille même.Cela n'a fait que repousser ce qui devait arriver. renseignement pris sur divers forums,il s'avère que je ne suis pas un cas isolé,mais qu'il y a une serie de lentille qui sont fragiles.Donc sachant que Audi ne font pas reparer les RNS-E,sachant que je l'ai acheté sur Ebay donc racheter un autre poste (trop cher) donc une solution:changer la lentille. j'ai recuperé un tuto sur le fameux site http://audiforum.us/ mais en anglais et acheté la lentille a un des membres de ce forum aussi (rabbit) pour 112 euros port compris.il vend aussi le lecteur DVD au complet pour 217 euros (il lui en resté plus qu'un il y a 3 semaines) Donc je suis passé a l'action ce week-end et pourquoi pas en faire profiter tout le monde.passons au choses sérieuses.(certaines photos sont de moi ,les autres du tuto que j'ai récupéré) on commence par laisser dans le RNS-E,un vieux cd (juste pour que la lentille soit plus accessible pour son demontage) Sortir le RNS-E mais ne le debrancher pas tout de suite,faire basculer l'ecran et avant qu'il ne se referme tout seul apres un certain temps debranchez le poste. et vous devrez vous retrouver avec cela on commence par retirer ces 3 vis.Attention,munissez-vous des bons outils pour eviter de deteriorer les vis Apres on retire les 3 vis du carter du dessus et les 2 du carter du dessous On attaque les cotés gauche et droite Faites bien attention comment sont montée ces 2 parties(rectangle rouges) car elles vont se détachées par la suite Retirer le carter du dessus,Desolé pas de photos On va retirer l'ecran LCD,donc on débranche ce connecteur(cable noir) et en tirant sur la facade tout devrait se detacher,attention a bien enlever la nappe se trouvant derriere l'ecran lcd Maintenant on va retirer le lecteur DVD,6 vis au total une fois les 6 vis enlevées,on debranche la nappe,alors 2 photos pour vous montrer comment la retirer Ouvert,on remonte la partie marron vers le haut pour liberer la nappe fermé,on rabaisse la partie marron pour bloquer la nappe Donc maintenant vous avez entre vos mains le lecteur DVD passons aux choses serieuses et avant demontage regardez bien comment est monté le bloc lentille,comme par exemple a cet endroit sur la photo On va dessouder la nappe,n'utilisez pas un fer trop puissant.Moi j'ai glissé un tournevis sous la nappe a l'endroit du point de soudure afin de la decoller dés que j'ai mis mon fer pour retirer la nappe faut tirer sur les 2 petits "fermoirs" marrons ensuite tirer legerement sur la nappe(cercle rouge) Retirer les 2 vis du bloc lentille qui de ce fait l'axe et le "chariot" vont se demonter ainsi que le bloc,donc avec vos petites mains c'est assez facile Si vous etes arrivé jusqu'a la,refaire la meme chose en sens inverse :bigthumbup: Pour info,lorsque j'ai tout remonté,rebranché le post dans la voiture,devinez quoi:Lecteur dvd endommagé veuillez contacter votre concessionnaire Audi,aucune reaction du lecteur,ejection impossible :( je redemonte tout et je recherche pourquoi,en fait la seule chose que j'ai fais et de positionner correctement le bloc,je m'explique il y a un micro-switch qui indique surement la position initial du bloc lentille (voir photo tel que je l'avais remonté mais en fait il faut le mettre completement en butée(pas visible sur la photo)mais qui actionne justement ce micro-switch voila,voila c'est tout,par contre vu que je n'ai pas trop envie de rechanger ma lentille dans quelques mois,on ne sait jamais,j'ai decidé de retirer le dvd de navigation quand je n'utilise pas le GPS car il ne faut pas oublier qu'il fonctionne en permanence meme lorsque l'on ne rentre pas de destination bye bye
  19. winblows
    DVD navigation illisible
    bon je viens d'effectuer le changement de ma lentille,un tuto viendra bientot car moi aussi apres un nettoyage il a marché un certain temps mais par la suite plus rien
  20. moi je l'ai et je n'ai constaté aucun changement particulier
  21. es tu passé par la fonction dans le set up "effacer les donnees utilisateur"??
  22. winblows
    RNS-E Partie Téléphone
    surement que ton rns-e n'est pas configuré correctement,il est declaré sans telephone installé moi j'ai eu le meme probleme mais a l'inverse,il etait codé pour un telephone alors que j'en avais pas
  23. winblows
    si tu as le bose,tu devrais savoir que justement ce n'est pas systematiquement le volume qui augmente ou diminue,il influence plus particulierement sur la courbe de frequence selon les bruits ambients (mode dsp integré dans l'ampli bose)alors que le gala joue uniquement sur le volume sinon pour tous les parametres dans l'engeneering mode,aucune idée pour le reset tu n'as rien a craindre cela ne fait strictement rien sur les reglages du poste.
  24. peut -etre que tu trouveras ton bonheur ici
  25. winblows
    Question sur le RNSE
    moi ce n'est pas au niveau du plafonnier que j'ai 2 petites boules :MdrDevil: ,desolé c'etait trop tentant :je_sors:
