En premier temps voyant de préchauffage qui clignote
Ensuite voyant moteur et esp avec le feux stop allumé.
Scan 7 erreur torque powertrain
Et scan vcds :
Saturday,15,November,2014,19:45:07:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8E25A542233 License Plate:
Mileage: 147490km-91646mi Repair Order:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E25A542233 Mileage: 147490km/91646miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 F HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G000AG 0040
Revision: --H01--- Serial number:
Coding: 0011171
Shop #: WSC 06314 000 00000
VCID: 2241F2C8FD31300EA27-8077
8 Faults Found:
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 002 - Electrical Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2205 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Temperature: 83.7°C
Duty Cycle: 50.1 %
Voltage: 14.36 V
Duty Cycle: 0.4 %
008209 - Intake Manifold Flap; Bank 2
P2011 - 001 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 31
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2226 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Voltage: 14.36 V
Duty Cycle: 0.4 %
Duty Cycle: 0.4 %
Duty Cycle: 54.8 %
012696 - Control Circuit for Intake Manifold Runner (Bank1)
P3198 - 002 - Implausible Signal
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2205 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Voltage: 14.36 V
Duty Cycle: 0.4 %
Duty Cycle: 0.4 %
Duty Cycle: 55.2 %
012697 - Control Circuit for Intake Manifold Runner (Bank2)
P3199 - 002 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2205 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Voltage: 14.36 V
Duty Cycle: 0.4 %
Duty Cycle: 0.4 %
Duty Cycle: 55.2 %
005121 - EGR Valve (N18)
P1401 - 001 - Short to Ground
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2226 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Voltage: 14.36 V
Duty Cycle: 94.3 %
Mass Air / Rev.: 511.1 mg/str
009255 - Exhaust Gas Recirculation Cooling Valve Control Circuit
P2427 - 001 - Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2226 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Duty Cycle: 21.9 %
Voltage: 14.36 V
Bin. Bits: 00101010
001393 - Brake Switch (F)
P0571 - 001 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1134 /min
Torque: 101.4 Nm
Speed: 14.6 km/h
Voltage: 14.36 V
(no units): 0.0
(no units): 0.0
Bin. Bits: 00000100
P3348 - 003 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2205 /min
Torque: 159.9 Nm
Speed: 101.9 km/h
Temperature: 83.7°C
Duty Cycle: 50.1 %
Voltage: 14.36 V
Duty Cycle: 0.4 %
Readiness: 1 5 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: 00000001 Serial number: 0000999
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: E4CD34D027A5FE3E90B-80B1
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 000 - Electrical Malfunction
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 147453 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 2144 /min
RPM: 2048 /min
RPM: 864 /min
(no units): 48.0
(no units): 42.0
Temperature: 63.0°C
T.B. Angle: 19.2°
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004426
VCID: 2757E3DC9613D526F59-8072
1 Fault Found:
00526 - Brake Light Switch-F
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x6880
Hex Value: 0x4002
Hex Value: 0x00FF
Hex Value: 0xFFAF
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
VCID: 6BDFDFEC197B3146511-5072
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0503
Coding: 01031
Shop #: WSC 04743
VCID: 397335A423A753D693D-4A3A
1 Fault Found:
02071 - Local Databus
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H11 3530
Revision: 91H1135 Serial number: 0036M003SH4/
Coding: 0033622
VCID: 3B7F2FAC7A9B61C6811-806E
Subsystem 1 - Serial number: 6332DRB401624D1DN
Subsystem 2 - Serial number: 6342DRB40163902CH
Subsystem 3 - Serial number: 6352ARB4004F1642E
Subsystem 4 - Serial number: 6362ARB4004F1A71L
Subsystem 5 - Serial number: 63729RB40056D497R
Subsystem 6 - Serial number: 63829RB40056D4F3U
1 Fault Found:
00590 - Igniter 2 for Passenger Airbag (N132)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04141
Shop #: WSC 06314
VCID: 41835D444B770B16DBD-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007141
Shop #: WSC 00001 001 66865
VCID: 336F078C51CBA986591-5072
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007141
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BR
Component: Komfortgerát T23 3232
Coding: 06768
Shop #: WSC 06314
VCID: 820112488EF1500E027-4A3A
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 1315
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Coding: 0000005
VCID: 397335A470A753D693D-806C
Address 77: Telephone Labels: None
VCID: 55AB9914BFFF97B6975-5000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End --------------
J'ai oublié de me présenter. Je m'appelle nathan je suis de Bordeaux Et j'ai une Audi a4 3.0 TDI quattro TI 204 ch 2005.
