winblows
Tout ce qui a été posté par winblows
Pour lui dire que tu as raccorder un chargeur,tout simplement STG 17 (Instrument cluster) -> Adaptation -> Function 10 -> Channel 62 +01 - Radio +02 - Telefon +04 - Navigation +08 - Telematics +16 - Instrument Cluster To add navigation, add +4 to the current value. STG 56 (Navigation System) -> Coding -> Function 07 0?xxxxx: Model 1 - Lamborghini 2 - Audi A3 (8P) 3 - Audi A4 (> 2004) 4 - Audi A4 Cabriolet (> 2004) 5 - Audi A6 (< 2004) 6 - Audi TT (> 2007) (sw US 0150+, EU 0500+) 7 - Audi R8 (sw US 0150+, EU 0500+) 0x?xxxx: Diagnostics for front speakers 0 - activ 1 - inactiv 0xx?xxx: Sound characteristics 0 - linear 1 - Audi A4 (> 2004) 2 - Audi A6 (< 2004) 3 - Audi A4 Cabriolet (> 2004) 4 - Audi TT (> 2004) 5 - Audi A3 (8P) 9 - Bose Soundsystem 0xxx?xx: Telephone/telematics 1 - no telephone (supply voltage for microphone actively) 2 - Mobile phone preparation (Temic - Speisesp. Microphone inactively) 3 - Mobile phone preparation (Cullmann - Speisesp. Microphone inactively) 4 - Mobile phone preparation (Nokia - Speisesp. Microphone inactively) 5 - Telematics Europe (supply voltage microphone inactively) 6 - Telematics US (supply voltage microphone inactively) 7 - Base plate diagnostic capable with comfort control 0xxxx?x: Options I 1 - default 2 - Digital-Radio 3 - Satelite-Radio 4 - Satelite- and Digital-Radio 5 - AUX in (Euro sw 0650+) 6 - AUX in and DAB (Euro sw 0650+) 0xxxxx?: Options II 1 - default 2 - TV-Tuner 3 - CD-Changer 4 - TV-Tuner and CD-Changer 5 - Multifunction Steering Wheel 6 - TV-Tuner and Multifunction Steering Wheel 7 - CD-Changer and Multifunction Steering Wheel 8 - TV-Tuner, CD-Changer und Multifunction Steering Wheel STG 56 -> Adaptation -> Function 10 -> Channel 001 (Tires) See http://de.openobd.org/audi/rns.htm#reifen -> Channel 002 (GALA) 0 - Self calibration 8 - Audi A6 (4B) 43 - Audi A3 (8P) 45 - Audi A4 (> 2004) -> Channel 003 (Language) 0 - German 1 - English (UK only) 2 - French 3 - Italian 5 - Spanish 7 - English (USA only) -> Channel 004 (rear view camera - US SW Lamborghini mode only, EU SW only with SW 0600+) 0 - disabled 1 - enabled -> Channel 005 (TV in motion) 0 - off 1 - up to 5 km/h 250 - unlimited (unlocked units only, otherwise value will not store) -> Channel 007 (Settings) +01 - Distance in miles +02 - Speed in mph +04 - time in am/pm +08 - Date in MM:TT:JJJJ +16 - Repeat voice commands -> Channel 008 (GALA) 000 - GALA off 001 - Charakteristics 1 002 - Charakteristics 2 003 - Charakteristics 3 004 - Charakteristics 4 005 - Charakteristics 5 255 - GALA via microphone (Bose AudioPilot) -> Channel 010 (Region) 0 - Northern hemisphere (Europe, North America) 1 - Southern hemisphere (Australia) 2 - Southern hemisphere (South Africa) Reverts back to 0 after loading software update -> Channel 011 (undocumented) -> Channel 016 (undocumented) -> Channel 017 (undocumented) -> Channel 018 (Startup Logo, sw US 0150+/EU 0500+) 0 - Default 1 - S3 (EU 0500+ only) 2 - S4 (EU 0500+ only) 3 - RS4 (EU 0500+ only) 4 - TT 5 - R8 -> Channel 064 (undocumented) -> Channel 065 (Read Test) -> Channel 066 (Self Test) -> Channel 067 (Eject CD/DVD) 000 - default 001 - eject CD/DVD 255 - eject button locked, no eject possible -> Channel 068 (TV test screen) -> Channel 069 (Display Mechanism) 000 - closed 001 - open 200 - partly opened (blocked) 255 - unknown position -> Channel 070 (Display Brightness) 0 - off 1 - 20% 2 - 40% 3 - 60% 4 - 80% 5 - 100% -> Channel 097 (Downgrade Software) 0 - Normal operation, unit performs updates only 1 - Force downgrade to older version, requires older DVD/CD
bon tu verras bien a quoi ressemble ce fameux CD (copie)ou original.Si il l'a eu en amont de la concession ;c'est un poste qui s'est "perdu"en quelque sorte
justement c'est parce qu'il existe ce type de logiciel que j'ai un doute car le code pin est attribué au poste en sorti usine donc qu'il soit de 1er main ,seconde ou troisieme je ne vois pas pourquoi il n'y en aurait pas ou plus
vagcom tout simplement pour declarer le chargeur sur ton rns-e
le prix reste correct mais faut etre sur que c'est bien l'ecran qui est HS
bientôt la fin mais tu n'as pas vraiment 2 mains gauche
oui multilingue
j'y crois pas une seconde
beaucoup plus simple que de changer la lentille (voir sujet epinglé) donc si tu es un minimum bricoleur et minutieux ça devrait le faire. As tu eu des infos via Rabbit ?
le mien etait fourni avec la carte d'origine audi (format carte de visite) avec le code
dans ce cas il a hacké le firmware pour activer la fonction SDS.Mais te sera inutile si tu n'installes pas le micro
Vu que tu as démonté ta boite a gant tu devrais voir la traverse métallique sous la planche de bord pour y fixer l'antenne bon courage pour la suite
si tu enregistres ta voiture sur myaudi.de , normalement en entrant ton VIN (ton numero de chassis)tu auras la liste de tous les équipements de ta voiture
comme c'est marqué le R , H et N sont avec le SDS Sinon pas de probleme d'incompatibilité le firmware t'apporte pas grand chose sauf si tu as un firmware inferieur au 0500.
Porte Golebet accoudoir arrière qui ne rentre plus !
winblows a répondu à un(e) sujet de JaYmZ666 dans A4 B8 - (2007 à 2015)
si cela peut t'aider -
si il prend les cartes sdhc c'est bon et si la presentation des mp3 se fait comme sur les photos du premier post c'est tout bon
il semberait que la version T est celui qui a le dernier firmware (0650) d'installé 8E0 035 192 T Audi A4 Europe, MY 2008, 8E B7, sw 0650
Surement une question de taille,regarde si les fichiers qui n'apparaissent pas,ne sont pas les plus gros
Par rapport aux schemas que je t'ai mis plus haut si tes haut parleurs coïncident bien avec ceux du rns-e tu n'auras pas de soucis
A3 8P Changement de langue de la commande vocal
winblows a répondu à un(e) sujet de yasstun dans Multimédia
il me semblait que l'on pouvait changer la langue via le menu du RNS-E dans les options du menu "son" -
ton autoradio est un double din ou un simple din tu trouveras sur ces 2 liens la difference entre ces 2 postes (si l y a des differences) choris et/ou symphony RNS-e
Il n'y a rien de compliqué.C'est quasi du plug and play.Juste un pin ou 2 (si bose) a déplacé sur le connecteur .Après pour la réception FM ,t'inquiète tu recevras toujours la FM mais en moins bon et tu auras un défaut au VAGCOM. Sinon tu changes les 2 amplis,tu as toutes les refs et tout ce fait au niveau du hayon (rien de bien compliqué)
De quelle année est la voiture ?
ressemble t-il a celui la si oui il lit les mp3
