The Lupe
Utilisateur Novice
À propos de The Lupe
    Christian
    Beersel
    Audi S6 2024
    V6 TDI
124 visualisations du profil
  1. J'ai acheté une S6 de direction Audi Approved du 09/2024 en 06/2025; et j'ai demandé une extension de garantie pour sécuriser mon investissement. Ceci est impossible me répond WeCare (D'ieteren). Car ce n'est pas possible pour un véhicule âgé de plus de six mois. Or pour des raisons fiscales ils ne peuvent pas les vendre avant 6 mois d'immatriculation (?). Après l'impossibilité d'utiliser les badges autoroutiers en France parce que le pare brise isolant ne permet pas leur lecture; et diverses "mises en sécurité" intempestives requérant chacune un passage en concession, je commence à douter de mon choix de véhicule. Avez vous aussi connu de telles mésaventures ?
  2. Trouvé ceci https://audi.tolltickets.com/fr/faq/ If your windscreen is fully coated or if you are unsure whether it is, we can only recommend that you hold the toll box out of the side window when you come to the toll station. Attention when holding the toll box out of the side window: The toll box must already be held out of the side window when approaching the toll station (approx. 100 m in advance). This is important so that the antenna signal of the toll station can activate the device from sleep mode. Please orientate the toll box so that the holder faces forward towards the toll station. Please do not wave with the toll box. It is indeed often the case that some models of the vehicle manufacturers Porsche, BMW, Mercedes, Audi, Tesla etc. and usually some electric vehicles have fully coated windscreens without recesses of the coating. In these cases, the device must indeed always be held out of the window when approaching the toll station. Unfortunately, we have no influence on this fact, as the funtioning of the toll boxes is determined by the toll operators - Manufacturers of vehicles sold in Germany often do not include a recess for toll devices due to the non-existent passenger car toll in Germany.
  3. Merci pour ta réponse mais dans le cas de l'option pare brise acoustique (code 4GR), la zone en pointillé à coté du retro ne permet pas la lecture par le portique; Audi me l'a confirmé ainsi que AREA qui m'a confirmé connaitre le problème sur certains modèles "haut de gamme" chez Audi; Mercedes et BMW; mais qui n'a aucune solution à proposer. Ce qui interdit l'usage des voies rapides T aux péages avec un véhicule doté de cette option !. D'où ma deuxième question, le vitrage du toit ouvrant est-il aussi "isolant acoustique" pour envisager de coller le badge sur le vitrage du toit ouvrant. D'ailleurs, sans savoir si il pourra être lu par les portiques; l'angle de lecture n'étant pas le même. A essayer tout de même; sinon ce sera passage obligé par les bornes de paiement et perte de temps.
  4. Le pare-brise acoustique optionnel (code 4GR) de mon S6 Avant diesel 2024 ne permet pas la lecture des badges de péage autoroutiers, donc pas d'utilisation des voies rapides T. Quelqu'un aurait-il une solution ? , Merci Question subsidiaire: le vitrage du toit ouvrant est-il également isolé ?
  5. Bonjour, Après quelques recherches nocturnes voici les captures d'écran des tableaux de réglage actuels de la jauge manuelle en fonction de la génération de votre moteur. J'espère qu'ils pourront vous servir. Voici le lien pour d'autres informations éventuelles : https://cardiagn.com/audi-a6-c8-2020-2023-workshop-manual-oil-gauge-tester-t40178-service-values/ NB: Bien content d'avoir trouvé pour mon moteur diesel DMKD de 2024 ;-)
  6. Bonjour, y a t il une liste mise à jour des réglages de cette sonde pour les modèles plus récents (S6 diesel 2024 moteur DMKD) ? Pour info ci-dessous la liste en ma possession s'arrête au moteur DDDA Merci Vue d'ensemble des moteurs TDI avec valeurs de réglage de la jauge de niveau T40178.pdf Vue d'ensemble des moteurs TFSI avec valeurs de réglage de la jauge de niveau T40178.pdf
  7. Je viens d'acquérir un S6 Avant Diesel de direction. J'ai un doute quand à la fiabilité de la jauge d'huile électronique. J'ai lu les posts concernant l'outil de jauge manuel VAG T40178 et je l'ai commandé; par contre je ne trouve aucune information concernant les cotes pour régler cette jauge pour mon moteur (fabrication en 2024) . Mon code moteur est DMKD (V6 3.0l 344cv). Quelqu'un aurait cette information , merci d'avance
  8. Je viens d'acquérir un S6 Diesel de 2024 de direction; sous le capot moteur, l'étiquette d'huile précise d'utiliser de l'huile VW 504.00 - VW 507.00 SAE 0W30, mais sur l'historique des entretiens d'AUDI il est noté vidange à 29.000 km avec de l'huile Castrol SAE 5W30. Alors 0W30 ou 5W30 ?
  9. Pseudo : The Lupe Prénom : Christian Age : 71 Localisation (Ville ou Département/Région ou Canton, évitez d'être précis) : Beersel - Belgique Métier/Etudes : retraité Vos voitures actuelles : Ma toute première Audi achetée en Juin 2025. Une S6 diesel 2024 de direction avec 40.000 km. Elle sera garée à côté d'une Porsche 987.1 2,7l de 2005 qui est chez moi depuis 2015 Vos anciennes autos : Landrover Discovery HSE Luxury de 2019; Jaguar F-Pace de 2018; Subaru Outback de 2010, etc .... Des passions : Motard passionné; une KTM Adventure 1190 de 2016 pour promener Madame et une Aprilia Tuono V4 Factory de 2022 pour aller "jouer" en solo Comment avez vous connu ce forum ? Recherche Goggle Pourquoi y êtes vous inscrit ? Chercher es informations techniques, capacité d'huile moteur (impossible à trouver dans le livret fourni), fréquence des entretiens, viscosité de l'huile recommandée, etc ... Votre première impression ? Favorable Autres (texte libre)... : Merci pour l'acceptation
