20vt
Tout ce qui a été posté par 20vt
  1. je ferais les essais en 3 alors :)
  2. ok mano merci je ferais les teste demain :)
  3. moteur amk jai fait les teste en 2eme
  4. voici les logs du DM et du turbo vous en penser quoi ? ,0.02,3600,71.4,5.78,59.78,,,,,,,,,, ,0.30,3640,32.3,2.04,6.03,,,,,,,,,, ,0.60,3320,13.5,1.70,4.19,,,,,,,,,, ,0.91,2400,30.8,4.08,24.75,,,,,,,,,, ,1.21,2440,78.9,6.80,41.11,,,,,,,,,, ,1.51,2720,90.2,7.14,54.08,,,,,,,,,, ,1.81,2880,111.3,8.84,67.31,,,,,,,,,, ,2.11,3120,128.6,9.52,86.19,,,,,,,,,, ,2.41,3400,150.4,10.88,106.78,,,,,,,,,, ,2.72,3680,179.7,12.92,138.36,,,,,,,,,, ,3.02,4000,191.7,14.62,168.94,,,,,,,,,, ,3.32,4400,191.7,17.00,174.19,,,,,,,,,, ,3.62,4760,191.7,15.64,173.78,,,,,,,,,, ,3.92,5120,185.7,15.30,181.11,,,,,,,,,, ,4.23,5440,177.4,14.62,180.61,,,,,,,,,, ,4.53,5720,170.7,14.28,184.11,,,,,,,,,, ,4.83,6000,166.2,14.28,190.22,,,,,,,,,, ,5.14,6280,160.9,13.60,192.69,,,,,,,,,, ,5.44,6560,154.1,13.26,194.25,,,,,,,,,, turbo ,,,,,,0.02,4120,42.9,980.0,1140.0,,,,, ,,,,,,0.30,4160,44.4,980.0,1140.0,,,,, ,,,,,,0.61,4280,76.7,2480.0,1060.0,,,,, ,,,,,,0.91,4440,124.1,2500.0,1470.0,,,,, ,,,,,,1.21,4720,175.2,2460.0,2030.0,,,,, ,,,,,,1.51,5080,191.7,2440.0,2110.0,,,,, ,,,,,,1.81,5400,182.7,2370.0,2040.0,,,,, ,,,,,,2.11,5720,170.7,2290.0,1940.0,,,,, ,,,,,,2.41,6000,167.7,2200.0,1910.0,,,,, ,,,,,,2.72,6320,66.2,980.0,2420.0,,,,, ,,,,,,3.02,4240,119.5,2460.0,1360.0,,,,, ,,,,,,3.32,4360,166.2,2490.0,1850.0,,,,, ,,,,,,3.62,4560,191.7,2460.0,2260.0,,,,, ,,,,,,3.92,4720,191.7,2440.0,2190.0,,,,, ,,,,,,4.23,4920,191.0,2410.0,2110.0,,,,, ,,,,,,4.53,5080,188.0,2400.0,2050.0,,,,, ,,,,,,4.83,5200,182.7,2400.0,2050.0,,,,, ,,,,,,5.13,5360,179.7,2370.0,1990.0,,,,, ,,,,,,5.43,5480,175.9,2340.0,1950.0,,,,, ,,,,,,5.73,5600,171.4,2310.0,1950.0,,,,, ,,,,,,6.05,5760,168.4,2260.0,1930.0,,,,, ,,,,,,6.34,5880,169.9,2230.0,1920.0,,,,, ,,,,,,6.64,6000,169.2,2200.0,1940.0,,,,, ,,,,,,6.94,6080,19.5,2260.0,2060.0,,,,,
  5. bonjour a tous est-ce que le chargeur cd origine peut etre piloté par un autre autoradio que celui du concert 1 merci
  6. bonjour a tous j'ai retiré mon autoradio origine concert 1 et j'ai pas vue le cable du chargeur ?? ou est -il brancher ?? merci
  7. 20vt
    mano turbo
    moi j'etait 1b 1b1 bas dans les tours :)
  8. 20vt
    mano turbo
    sur le regulateur de pression d'essence :) c'est la que j'ai brancher le mien :)
  9. 20vt
    de retour
    oui c'est les tubes d'origine
  10. 20vt
    de retour
    le bruit est asser sourd une fois bien chaud :) et en pleine charge ca souffle vener :) je vais essayer de faire une video
  11. 20vt
    de retour
    merci dem's c'est un pote a moi qui a un magasin de pieces performance et competition en region parisienne :)
  12. 20vt
    de retour
    modif vidage de la ligne + supression de l'intermediaire ca fait pas trop bruit et ca souffle un truc de ding :)
  13. mon moteur a 138000km
  14. moi aussi j'ai quelque bricole frontale, air restrictor suprimé , n249 suprimé , ect... cette semaine je vais modifier ma ligne je verrais bien :)
  15. donc enfaîte ça vient de ma gestion alors ok merci mano je vais refaire ca au plus vite alors :)
  16. pourquoi il ya des personne qui ont 1.4 en stable jusqu’à 6000trs
  17. slt a tous , voila ca fait une semaine que j'ai fait une gestion chez un pote a moi mais le souci c'est que dans les tours la pression chute ?? en boost j'ai 1.5b et après arrivée a 6000trs j suis a 1b ca peut venir de quoi ? maintenant je sais que ici ya pas mal de gens qui sont reprog et je voulais savoir vos pression de turbo en boost et en stable pour me donner une idée merci a vous :)
  18. 20vt
    de retour
    j'ai suprimé le air restrictor :) a venir suppression de la ligne d’échappement :)
  19. j'ai eu aussi un souci avec l' haldex j'ai résolu le problème la semaine dernière j'ai testé ma pompe en direct elle tourne en continue ! donc la tienne doit etre hs moi perso j'ai changer mon boitier d'haldex et depuis ca fonctionne j'suis en 4RM tu doit entendre ta pompe quand tu mes le contact :)
  20. 20vt
    de retour
    jai enfin fini mon montage lol reste encore quelque modif a faire :)
  21. 20vt
    de retour
    non ca va pas trop galère j'ai pris mon temps ca va bien a faire :) merci dodo :)
  22. 20vt
    Pont arrière Haldex
  23. 20vt
    de retour
    oui une forge mais je vais la changer pour remettre une origine :)
  24. 20vt
    de retour
    des petites news supression de la N249 deplacement de la dump valve pose du frontal mais j'ai pas encore fini
  25. merci quentin :)
