sebtronic
À propos de sebtronic
  • Date de naissance 06/12/1976
    tarn
    TT MK1 225 TT MK1 VR6 / A3 2 2.0 tdi TT VR6 ABT S5 gris météore / mini cooper S A3 2.0 tdi sporback Q7 s-line
1 233 visualisations du profil
  1. juste ce que j'ai en photo pour le moment, avant la réalisation du glastint
  2. ça fait mal à la tête
  3. merci(s) :) je met en dessous les codes de l'auto, histoire pour moi de pouvoir complêter avec les options correspondante EOA no special edition 7AE cd changer 4UE air bag for driver and front seat passenger 6XF outer rear view mirrors: powered, heatedelectrically foldable, with memory function? 5SL outer rear view mirror 5RU outer rigth rear view mirror 1KD disc brakes rear JOR battery 380 A (80 Ah) 1LB disc brake front 1BE sports suspension/shock absorption 3FE electric slide/tilt sunroof with sun screen/sunblind 5MG decorative burr walnut inserts 7XO without additional cooling system/ headpipe cooling/headpipe insulation 4X4 side airbag, front and rear with curtain airbag FOA no special purpose vehicle, standard equipment 8GU alternator 140A OG1 gearshift lever OYK weight category rear axle weight range 10 OJH weight category front axle weight range 8 T9J components for base engine, unit 038.K 3NZ rear seat bench unsplit, backrest split folding 8JG headlight with gas discharge lamp for driving on the right U2A instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer XOA national sales program Germany 1N1 power steering 2ZQ leather trimmed multi-function steering wheel for airbag system 8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving) 9Q4 multi-function indicator/on-board computer with check control 8Z5 engine cooling system, type 1 D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J/TG0 7Q2 navigation system with color screen C1X alloy wheels 7 1/2J x 17 five-arm spider style, offset 45 7KO whithout tire presure warning light 4X4 side airbag, front and rear with curtain airbag VJ1 reinforced bumpers 6R2 leather gearshift boot 3L4 electric seat adjustment for both front seats, driver's seat with memory system 4KC side and rear windows tinted 3Y4 roll-up sun screen for rear side windows 4K4 radio remote controlled central locking operated from inside and separate trunk release 5D1 carrier frequency 433.92MHz 1SA whithout additional engine guard OGE emissions concept EU 3 Q1D sports front seats 4GH windshield tinted with windshield sunshield
  4. super , merci de ta réponse Julien :) j'vais me renseigner sur ces faisceaux oui pour les photos, je n'en pas encore, la voiture n'est à la maison que depuis 4 jours ... ça viendra :) bien je suis très supris par les options sur ce véhicule. J'ai disposé entre autres d'un s5 très équipé, et cette a4 possède à peu près les mêmes artifices ( une auto qui a tout de même 9 ans ! ) mis à part les radars de recul et les bi xénons ! surpris aussi de trouver au compteur un afficheur en couleur !
  5. Bonjour à tous pas nouveau sur le forum mais nouveau en A4 je me permet de presenter ici mon dernier jouet et en savoir un peu plus sur ce modèle. Il sagit d'un avant B6 avec le tdi 130 en bleu nuit... de 2003 ( plus toute jeune) acquis il y a 4 jours Elle est pas mal optionné toit ouvrant sieges sport cuir/alcantara electriques, chauffant av et arr à mémoire gps ... et visiblement la tv ou dvd mais j'ignore le fonctionnement bose, toujours un régal cette option :) regulateur limiteur frigo dans la boite à gant xénons auto pack rangement ( filets et coffres sous les sièges) et pack lumière visiblement rideaux sur les vitres arr air bag latéraux arrières alarme et antisoulèvement ect ect autour de ce nouvel achat, j'ai des petit projets pour embellir cette déjà très gracieuse auto. Changer l'ammortissement ... peut être du blisten B6 > ressorts ??? l'auto parait déjà assez basse, probablement un chassis sport changer le gps ... passer du rns existant au rns e auquel je suis plus abitué, plus grand changer le volant, pour un trois branches dans l'esprit d'une b7, en conservant les commandes au volant ... et le petit plus, des bas de caisse au porte types s4 Un detailling , histoire d'éffacer les microrayures un traitement glasstint à déjà été réalisé de ma part sur le 3/4 arr. Je me posais donc des questions sur la compatibilité, d'un nouveau GPS, d'un volant plus rescent sur cette auto. Si vous avez des retours d'expériences, je suis preneur :) Merci à vous
  6. magnifique ! félicitations
  7. hello q7 s-line 3.0 gris condor de 2008 reprog fochesato
  8. hello à toi et merci c'est avec plaisir que je renouvellerai l'expérience de la sortie Audoise :bigsmile:
  9. belle d'origine , je trouve que le PC s-line sublime encore plus l'auto, il me semble bien que les différences soient notables !!
  10. sebtronic
    Livraison !
    Bon courage pour ton attente :bigsmile: moi on m'a annoncé dessuite 11 mois d'attente ... ( mais avoué un délais qui devrait tourner vers les 8 mois :rolleyes: )
  11. /fracture de l'oeil / magnifique, jusque dans les moindre détails :malelovies:
  12. Ben ce sont des surpiqure colorées sur le volant pommeau de vitesse ... Idem pour le packj des tapis
  13. je reste fidèle au rouge magma :malelovies:
  14. merci ben j'ai profité de la modification de la commande pour rajouter des options suplementaires en compensation, un pack cuir audi exclusives, les tapis audi exclusive, pack coffre que j'avais oublié
  15. j'ai eu ces infos par ailleuir, et j'ai modifié en suivant la commande ---- > la boite tiptronic ne m'interresse pas , il sagit d'une B auto conventionnelle, mal renseigné j'espérais une boite type s-tronic.
