spinmar
Tout ce qui a été posté par spinmar
  1. Adaptive cruise control which is always together with audi breaking assist. More info here: http://www.audi.it/it/brand/it/tools/advice/glossary/adaptive_cruise_control.browser.filter_i_a.html It is a more complete and advanced system of cruise control.
  2. Are you sure? In italy it is an optional in all Q5 and it is usually very expensive.
  3. Problem solved. ACC available and full working. Well done. I must say one of the best optional I saw. If someone is interested in this retrofit for Q5>2011 let me know for some help. Bye
  4. Ok. I'll wrote to Johnny. Is it possibile that in all the forum nobody is using vag? I need only the long code of module engine and radar of a q5 with acc model year 2012/13. Thanks
  5. Who is interested in helping me? I suppose that in the forum there will be a q5 of 2012/13 with acc...... Can someone write the vag long code of module engine and radar? Thanks
  6. Hi guys I Need your help on this retrofit I did yesterday. I installed all and now I have cp on the radar. I need help on the code to insert on engine module. I knew to set bit 5 to 1 on byte 5 but it seems that on Q5 of years 2011 and up it is not true. So someone with acc on a q5 of 2011/12/13 could tell me the code of byte 5 and 6 of module engine? Thanks
  7. Jhonny, who is working on this project (installing the new firmware on MMi 3g unit)? In my opinion the problem is that MMi 3g+ has some hw different from MMI 3g and then if you install the new firmware you have some errors in drivers not found.
  8. Very interesting topic. It should be very useful if we could find a way to insert speed limit or installing the new MMI 3G+ software in our MMi 3G
  9. Sorry but it is not possibile in MMI 3G. Only with MMI 3G+ it is possibile.
  10. Remember that after updating fimrware and maps you will get the error "Please Check Software Version Management" and to remove that you have to use the VAG. It is only an error in module 5f but it's better to remove that.
  11. Yes you have to activate hidden menù using a vag cable and vcds. During the installation of the new firmware you loose the hidden menu activation. Module 5f->Adaptation 10-> read channel 06 and set the new value to 1. Test, save and done go back.
  12. Sorry but I should have a question about the update. I read page 7 several times but there is something which is not clear to me (I don't uderstand francais very well, sorry.....). In page 7 there is a photo where you can see ARU 9332 in white (after you chose the standard update). Did you have to select it and put Y? Thanks very much
  13. Good. So it should be sufficient to do once and the problem should be solved. :icon_smile:
  14. Johnny5377, sorry I'm writing in english but my francais is not good :icon_frown: I read in previuos post that you wrote to get always crack in the car because sometimes it seems that you get the error map is not activated. is it true? Did you get the error one time or more times? Does it happen only to you or other users?
  15. My garage is composed by my Q5 2.0 TDI 170 CV 2011: - color ibis - advanced model (xenon, cruise control, etc...) - bluetooth - sline exterior - 19'' wheels - light interior packet - parking plus A month ago I upgrade my car with MMi 3g HDD retrofit and OEM reverse camera. My MMI 3g is upgraded to 2012 maps and fw 206_3_D1
  16. Hi all, sorry I'm writing in english but I have to learn francais a bit better! I come from italy and I have an audi q5. I'm very happy to be part of your community. A great hello to everybody.
