Polat.sline
Tout ce qui a été posté par Polat.sline
  1. VAG-COM Version: Release 409.1-US Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 LJ Component: 1,9l R4 EDC 0000SG 4910 Coding: 00002 Shop #: WSC 63351 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 517 Component: ABS/ESP front 3429 Coding: 04259 Shop #: WSC 06435 1 Fault Found: 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 8E0 820 043 AA Component: A4 Klimaautomat 1219 Coding: 00000 Shop #: WSC 63351 5 Faults Found: 00532 - Supply Voltage B+ 53-00 - Supply Voltage Too Low 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01206 - Signal for Duration of Ignition: OFF 27-00 - Implausible Signal 00474 - Control Module for Immobilizer 49-00 - No Communications 00474 - Control Module for Immobilizer 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 09: Cent. Elect. Controller: 8E0 907 279 C Component: int. Lastmodul RDW 0606 Coding: 00011 Shop #: WSC 63351 5 Faults Found: 00474 - Control Module for Immobilizer 49-00 - No Communications 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01317 - Control Module in Instrument Cluster (J285) 79-10 - Please Check Fault Codes - Intermittent 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent 01312 - Powertrain Data Bus 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 16: Steering wheel Controller: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 02142 Shop #: WSC 63351 4 Faults Found: 00532 - Supply Voltage B+ 53-10 - Supply Voltage Too Low - Intermittent 01426 - Controls in Steering Wheel (E221) 49-00 - No Communications 00895 - Cruise Control Switch (E45) 37-00 - Faulty 00474 - Control Module for Immobilizer 49-00 - No Communications ------------------------------------------------------------------------------- Address 17: Instruments Controller: 8E0 920 900 K Component: KOMBI+WEGFAHRS. RB4 D37 Coding: 00100 Shop #: WSC 00000 WAUZZZ8E54Azyzyzy AUZ6Z0C0255076 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Controller: 8E0 959 433 BA Component: Komfortgerát TA7 1310 Coding: 06752 Shop #: WSC 08590 3 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01331 - Door Control Module: Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent 01332 - Door Control Module: Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent End --------------------------------------------------------------------------------------------------
  2. J'ai mis aucun câble sur la masse ,j'ai déjà les câble ,pas besoin de les faire , mais je peut pas demmarer la voiture en se moment ,attende que je vois fait une video
  3. quand je faisait un chek système avant , javez le logo de lave glaces si je me souviens bien ,la voiture a un problème de boite , donc je peut rien que ouvrir le contacte ,( starting desactiver by immobilizer ) donc c'est normale que je peu pas accéder le menu de odb ? je vais vous faire une vidéo c'est mieux
  4. d'accord mais j'ai toujours pas eu l'affichage qui dis manque de l'eau essuies glaces :reflexion: :nixweiss:
  5. non je sais pas comment on fait ca kilivinci tu peu être plus clair
  6. salut , j'ai le même problème sur la A8 de d'un copain, sa se met a tourner une fois le contacte est mise apparemment,
  7. Madingwada j'ai pas dis que jeté sur pour les palette et multiF mais pour odb je suis sur sa devrait marcher , quelque chose ne vas pas , ca marche mais pas comme il faut , je ouvre la porte , j'ai le dessin de la voiture au tableau de bord , j'appuis sur + ou - de odb sa me affiche le km a faire avec le réservoir
  8. c'est quoi le bonne référence , je commence a chercher
  9. nonnnn :( donc ya aucun moyenne de faire ca ?
  10. voila comme il est brancher en se me ment ,faut que quelqu’un vois si je me suis pas tromper
  11. si quelqu’un pouvez vérifier les fils de multifonction sa sera pas mal rouge bleu et noir , que j'ai sur la photo
  12. pour les référence , je vais essaye , mais j'ai pas les clé torx
  13. aiy aiy aiy le 2 eme photo sa viens d'une audi TT ,le 8 c'est le clackson ,et sur les b6 b7 c'est le 2pour clackson je vais vous faire des photo , sa sera plu claire :mur: :malelovies:
  14. Tu a d'origine le "N" ou tu acheter avec l'obd etc ? A tu le régulateur d'origine ? PS : Tu a une bague de rappel 6 pin ou 12 pin !!! Car les 6 pin sont incompatible pour le volant Multi. javez vu a l'auto-casse une b6 brule sa se voyer y avez régulateur et odb j'ai acheter le module de colonne entait avant je savez meme pas que sa se identifie avec les lettre comme N Q R ect , j'ai regarde le mien il a ni odb ni regul et l'autre il avez les 2 donc j'ai changer , et après j'ai mis le bouton odb +volant multifonction ,encore un peut de temps après j'ai installer les palette pour la bague de volant c'est un 12 pin ,se qui m'inquette le plus c'est k j'ai pas changer le bague de volant de b6 pour passer au b7 j'ai simplement changer l'embout de prise, possible que j'ai merder je sais pas se que javez a l origine comme référence , javez un volant 4 branche avec multifonction c tout pas de palette pas de regul pas de odb
  15. T'as fait un apprentissage du VIN ?? Y'a plein de manière de la faire ... leon j'ai pas compris excuse moi
  16. donc c'est quoi le problème le module vous penser ? ya un ami il a un module avec odb écran blanc régulateur mais c'est un B6 , vous en dite quoi quand ya odb et regul a se moment la les palette et multifonction est ajout able ?
  17. waoo les gas je suis choque d'un coup les connaisseur sont sorti a lavant :) dit moi se que je doit vérifier , aujourd’hui j'ai essaye plein de truck aucun résultat quand j appuis sur reset de odb sa me fait écran noir ,c'est bizarre , je re appuis sa reviens
  18. ok disent que j'ai rien dis jusque la , comment vous m expliquer cela dans la photo ya regul et odb ,et il finit par un N je lai trouver sur le bon coin , alors que votre tableau dis le N fait que regul
  19. chez un pot ya une module avec odb et regul déçu , je sais pas encore le référence , si ya les 2 déjà odb et regul , multifonction et palette sera compatible ou ca aussi il faut voir
