Noura
À propos de Noura
  1. Pour info j'ai trouvé comment activer le Bluetooth sur mon mmi 3G et la manipulation est uniquement software via l'interface VAG
  2. J'ai un vag et suis sur bruxelles
  3. recherche comment activer le bluetooth sur le mmi 3G
  4. recherche comment activer le bluetooth sur le mmi 3G
  5. j'ai trouvé ça : Coding * 00?0xx0: MMI System o 1 = MMI/Sound System High o 2 = MMI/Sound System Standard * 00x0?x0: Installation List o 9 = Vehicle with MOST-Databus * 00x0x?0: Voice Control Language o 0 = Voice Control OFF o 1 = German (Rest of World) o 2 = English (United Kingdom) o 3 = French (Rest of World) o 4 = Italian (Rest of World) o 5 = Spanish (Rest of World) o 6 = Spanish (USA) o 7 = English (USA) o 8 = French (Canada) o 9 = Speaker depend Voice Selection Adaptation Optical Performance [select] [77 - Telephone] [Adaptation - 10] Channel 096 [Read] The optical performance of the MOST bus can be adapted. * 0 = Normal Performance * 3 = Reduced Performance (-3 dB) [Test] [save] [Done, Go Back] [Close Controller, Go Back - 06] Bluetooth [select] [77 - Telephone] [Adaptation - 10] Channel 133 [Read] * 0 = Bluetooth OFF * 1 = Bluetooth ON [Test] [save] [Done, Go Back] [Close Controller, Go Back - 06] Hands Free Function [select] [77 - Telephone] [Adaptation - 10] Channel 134 [Read] * 0 = Hands-free active while Bluetooth connection is active but without cell phone engaged * 1 = Hands-free only active with cell phone engaged [Test] [save] [Done, Go Back] [Close Controller, Go Back - 06] Bluetooth Pass Key [select] [77 - Telephone] [Adaptation - 10] Channel 135 [Read] Set the 4-digit Bluetooth pass key using this channel. [Test] [save] [Done, Go Back] [Close Controller, Go Back - 06] sur http://wiki.ross-tech.com/wiki/index.php/Audi_A4_%288K%29_Telephone_Preparation_%28MOST%29 mais j'arrive pas à passer le menu 77 j'ai un message d'erreur directement. Et je pense que je dois d'abord activer quelque chose dans le Hidden menu avant d'aller dans le menu 77. je pense que l'astuce est là c'est une activation à plusieurs étape.
  6. j'ai lu qu'il faut activer un menu cache pour avoir acces au controller 77 sur le vas5052A http://trick77.com/2009/07/23/unlocking-mmi-3g-hidden-menu/ 1.Select control module 5F in VAG-COM/VCDS 2.Select “Adaptation – 10″ 3.Select channel 6 4.Set the value to 1 5.Press test 6.Press save 7.Press “Done, Go Back”, close the controller and quit the software 8.There’s no need to restart the MMI, just press CAR + SETUP for 6 seconds to enter the hidden menu ici expliquent comment activer le controller 77 info différente http://audiforum.us/cables-adapters-antennas/8513-bluetooth-help.html
  7. j'ai un ami qui l'as justement et j'ai tester en allant sur le *Telephone - Controller 77 mais j'arrive pas a aller sur le channel 133 pour mettre la valeur à 1. j'ai un message d'erreur quand on va sur le controller 77 pas possible d'avancer. As tu une idee de la manip TopKool ?
  8. Sur VnsMedia activateur pour MMI 3G http://www.vnsmedia.com/?item=160&t=1277127783. il semble que se soit une simple manip sur le VAG
