windstar
À propos de windstar
    willy
    Algerie
    Audi A7
    TFSi
  1. Désolé de n'avoir pas répondu plus tôt. J'ai vendu mon Touareg entre temps.
  2. Hi Stu, two recommendations: check this thread: http://www.mytreg.com/index.php?/topic/58113-paring-and-configuring-rns-850-with-s3-and-rsap/ and follow the instructions regarding the pairing. and also in the green menu at: /diagnose/settings/tel_settings both NAD activation NAD operation mode must be checked. exit green menu, reboot + test But I’m pessimistic that it will work with an iPhone. I would like to be able to use Google either with the SIM installed or by using the iPhone as a hotspot to provide the data connection and without disconnecting the bluetooth telephone connection. I think this is what Windstar has already done but due to some translation problems for me I cannot exactly determine the steps followed, perhaps you can help with a simple and straight forward list of actions.
  3. At the end I followed the Tuto from here with three differences: set DNS to 8.8.8.8 do NOT install fair mode use DataPST.db from Noy
  4. Pour MMI 3GP et/ou RNS850 avec carte SIM le "fair mode" est contra productif. Après "uninstall fair mode" et reboot Google Earth semble marcher. Mais malheureusement pas de trafic en ligne (licence périmée) ni de petit bonhomme jaune pour street view.
  5. The internet access with the SIM card is working. I put it in an old windows mobile smartphone and Internet connection was there immediatly, see screens: https://1drv.ms/f/s!Aokd5aBZH-tBhDJH7FAdxwRCqWJu But in the RNS850 no luck. Don't know what could be wrong with the settings...
  6. I installed the Diag 2.01 from the first post: results here: https://1drv.ms/f/s!Aokd5aBZH-tBhC9kX19T4ha6OROv What to do now?
  7. sorry what are the cap threads? can You guide me in the right direction to find it? In the meantime some other pictures You asked for: https://1drv.ms/a/s!Aokd5aBZH-tBhCwsukNTcYPO1HlN
  8. What Do You mean with diag 2.01 is it a script to check internet connectivity of the RNS? Or how should I check it exactly?
  9. Still no luck. I have your DataPST.db installed and did exactly what You told me. Here in the folder are the requested pictures. https://1drv.ms/a/s!Aokd5aBZH-tBhCA15MRMXoRxjuJf
  10. Pas de chance :nixweiss: D'abord j'ai reinstalle "fair mode" dans le green menu -> bouton Google Earth toujours gris Ensuite j'ai installé la DataPST.db de NOY: 1. Langage du système maintenant Anglais et ne peut être changé 2. Toutes les stations radio sont effacées 3. Google Earth peut choisi maintenant mais apres quelques secondes de chargement: "No available Data for Google Earth"
  11. @NOY: as written before K0821 and 6.22.3 I uninstalled fair mode before applying the modifications of the DataPST.db I will try first reinstalling fair mode in the green menu and if doesnt help I will try the DataPST.db from You.
  12. Par curiosité j'ai installé SQLite Expert Professional Ensuite j'ai comparé les DataPST de NOY et la mienne au niveau des tb_intvalues. Beaucoup des valeurs sont differentes. J'ai bien trouvé "pst_key 4117" qui chez moi avait "pst_value 0" et dans le script de NOY etait a "1" J'ai donc modifié cette valeur dans ma DataPST.db de "0" a "1" et mit cette DataPST dans le script "write" Ensuite le script "write" sur mon RNS850 et malheureusement apres reboot toujours pas de "Google Earth" bouton toujours gris. La seule différence est que maintenant au démarrage il me dit que ma licence trafic en ligne est périmée. Il semble donc que 4117 ne soit pas la seule valeur a modifier. Toutes suggestions sont les bienvenues.
  13. Ok, compris. Mais pourquoi la grande différence en taille? voir: https://1drv.ms/f/s!Aokd5aBZH-tBhBY1KYGjxnHrllks
  14. In the meantime I executed the "read" script on my RNS850. The DataPST.db size is highly different from the one the "write" script should put on the RNS850 mine 45.056 Bytes the one from the script 38.912 Bytes Is there a tool to compare and edit these kind of *.db files ?
