NOY
Tout ce qui a été posté par NOY
  1. Hello miazza, Do understand that the Internet is in your rns 850 to install the script diagnostics - diag 2.01. Then it is necessary install DataPST.db with car-net services.
  2. Yesterday I turned off the video on the move, street view is not work. The car is in the garage, I'm not going anywhere. I know that on the map exactly possible to view street view, I approached the card as close as possible, but I do not appear yellow man icon and I can not enter the street view mode. It should work well https://www.drive2.com/l/9263500/ What do these settings green menu Green menu nav/map Enable Satellite Images Dasable Satellite Images
  3. Hi, what should be the value of the trace/tracescope green menu, there is a suspicion that I have an incorrect value, so not working street view? https://mega.nz/#!TowyiArQ!lN-LYC-qTSe88aCQtlz29OocS8q-5vD9GSvPXAjyJAI
  4. pf.conf and nws.cfg are the same as in the script MMI-3GP-GE-WIFI.zip unchanged.
  5. Try to change the ip wifi openwrt at 192.168.2.1 and dhcp option to 3,192.168.2.1 as my photo above.
  6. According to the diagnosis of rns no internet, no ping sites. You have a built-in modem in rns 850 and wifi hotspot rns 850, try to connect to an access point wifi rns 850 to check whether there is the Internet.
  7. I made a photo as it works on rns 850 through a router mr 3040 openwrt, is not working street view and I still do not know why, on tmc online I think this problem can be solved. My gsm ISP blocks www.orange.fr so there is no ping. https://mega.nz/#F!D1pknRgS!OgcCv-zu-167G5tUo_utrw
  8. Hi, I noticed in the green menu in the nav/trafficonline line Connection Last Session just 32 characters - this value is 72057594037862402. was this idea that values 72057594037862401 this md5 hash vin, 32 characters is very similar to md5, as well as a password shadow. I tried to shove my vin in file and calculate a hash, but the values do not coincide with the ... 401 from my home DataPST.db And of course I looked sniffer wifi interface when tmc online worked, but I do not want to share this with everyone.
  9. The first message of this topic, script is called MMI-3GP-Diag-v2.01.zip After seeing your photos, I can not figure out whether there is Internet via gsm.
  10. In order to understand whether there is in rns 850 internet, I use a script (diag 2.01), it is in the cap threads. The script allows you to ping the sites of green menu rns. config Show IP Settings
  11. I looked at your photos, everything is right gemmi component is installed, the settings green menu right. Does have rns Internet, whether pings go to sites (diag v.2.01 - allows you to ping websites) config Show IP Settings show these photos If the Internet is in the exact rns to try again write.rar my script, and then press the button google earth.
  12. If you have router mr 3020 use this firmware openwrt - Peppy Snowdrop 2.3.2 http://acs-house.ru/files/firmware-mr3020-bp2-3-ps2-3-4gmodem/ or you can use GoldenOrb from ofmodemsandmen.com from 01.04.2016
  13. Try install fair mode again and restart rns Yes, language is English and you will see my list of radio stations. Other settings green menu should be in the MMI-3GP-odiconnect-v1.0.pdf Next, you should try to press the green menu googleearth install gemmi persistent, then restart rns. Do the following photo of green menu and show me. googleearth Get info gemmi diagnose/coding/internal_modules_1+2 diagnose/settings/tel_settings
  14. Regarding tmc online, I'm not saying that this is not possible, I have it worked until 30.05.2016 and i used audi values, and was blocked audi server. For tmc online requires a value 32783 in adaption channel 69 (vcds) or the value of 32783 to 40960 tb_intvalues file ​​DataPST.db And the correct values ​​in tb_stringvalues ​​DataPST.db file pst_is pst_namespace pst_key pst_value 6 676990753 72057594037862401 11111111111111111111111111111111 * Audi * DE 7 676990753 72057594037862402 11111111111111111111111111111111 72057594037862401 72057594037862402 values ​​and need to be taken from those who DataPST.db tmc online works. 72057594037862401 is coded vin 72057594037862402? See my DataPST.db in write.rar I used the values ​​and 72057594037862401 and 72057594037862402 audi of up to 3 years and I have worked tmc online 1 month.
  15. windstar, you should try to use my DataPST.db and see whether the active google earth, so we have chores. You can always return back to your DataPST.db via write the script. We must push install fair mode in the green menu. And what firmware version you have and maps ?
  16. frankiegom, Need to set router IP wifi 192.168.2.1 and wifi router DHCP option 3,192.168.2.1 to make it work and installFairMode also. Ip router default 172.16.1.254 Another check mark should be put in the settings wifi dhcp openwrt Force DHCP on this network even if another server is detected. rns 850=mmi3g+ no mmi3gp
  17. frankiegom, IP mmi (rns) 192.168.1.1 It is logical that the gateway must be on the same subnet with mmi, ie 192.168.1.254 In my case touareg is not working, we tested it on 3 machines if reserve 3,192.168.1.254 rns the gateway does not receive from the router openwrt. But it is necessary to change the ip wifi openwrt router 192.168.1.254 to 192.168.2.1 on the team and for dhcp c 3,192.168.1.254 on 3,192.168.2.1 rns and receives this gateway, pings to sites are in rns appears internet. Despite the fact that different subnet in rns has internet, checked on 3 machines without sim. If you do not believe me, tomorrow I'll do a photo a green menu (diag v 2.01.) - Show ip settings. Regarding DataPST.db so - a file from a working system with sim card, just does not work google street view. What is in DataPST.db responsible for Google services for Audi, maybe you know?
  18. DataPST.db saved a list of radio stations (you have more saved radio stations), language settings, adaption channels (VCDS 255 channels) and your vin.
  19. I have noticed a bug about the gateway. IP wifi router should be 192.168.2.1, respectively, and dhcp be 3,192.168.2.1 If you leave the value as a guide to 192.168.1.254 and 3,192.168.1.254 then rns not want to receive gateway - something does not work, a bug.
  20. The script write.rar copy their DataPST.db, so you can put things back. I'm using SQLite Expert Professional for editing DataPST.db.
  21. Windstar, rns a internet, itinéraires aller. Vous devriez essayer d'appliquer script write.rar et cliquez sur le bouton précédemment inactive google earth.
  22. Tout droit, write.rar contient déjà toutes les lignes nécessaires à DataPST.db pour activer Google Earth pour touareg, mais je ne travaille pas street view. Je veux vous poser une question comme un gourou de ce forum MMI-3GP-GE-WIFI.zip a fichier sqlite.xml -<int_row status="invalid"> <key>45056</key> Je n'effacer cette valeur, google maps? <value>1</value> <namespace>4</namespace> </int_row> -<int_row status="invalid"> <key>40960</key> <value>32783</value> pour tmc en ligne <namespace>4</namespace> </int_row> -<int_row status="invalid"> <key>4100</key> <value>1</value> activation du menu vert <namespace>4</namespace> Pour touareg doit avoir ces valeurs "4" "4115" "0" "4" "4116" "0" "4" "4117" "1" "4" "4118" "40" "4" "4119" "20" "4" "4120" "8999" "4" "4121" "132121883" "4" "4122" "336333312" "4" "4124" "131991064" "4" "4125" "385875968" "4" "4126" "3241187" "4" "4127" "132187672" "4" "40960" "32783" "676990753" "72057594037862404" "1" Ce qui est responsable de ces valeurs dans DataPST.db ou vcds? (2) -Vehicle_configuration-online_POI, OFF (3) -Vehicle_configuration-online_POI_voice, OFF (4) -Vehicle_configuration-online_portal_browser_services, OFF (5) -Vehicle_configuration-online_navigation, OFF (6) -Vehicle_configuration-online_street_view, OFF Je ne travaillais pas sur la street view touareg, et je ne sais pas quelle valeur devrait être DataPST.db, ou l'étendue de vcds de canal d'adaptation?
  23. Ne vous inquiétez pas, essayez read.rar et de garder votre DataPST.db Ensuite, appliquez write.rar, se connecter en ligne à rns et cliquez sur Google Earth.
  24. Tout d'abord, vous devez lire DataPST.db cp -v -r /mnt/efs-persist/DataPST.db $dstPath/db/efs-persist/old/ cp -v -r /HBpersistence/DataPST.db $dstPath/db/HBpersistence/old/ cp -v -r /mnt/hmisql/DataPST.db $dstPath/db/hmisql/old/ Puis ajouter DataPST.db tb_intvalues 4 4117 1 et écrire de nouveau mount -uw /mnt/efs-persist mount -uw /mnt/efs-system mount -uw /mnt/hmisql cp -r -v $dstPath/read/DataPST.db /mnt/efs-persist/ cp -r -v $dstPath/read/DataPST.db /HBpersistence/ cp -r -v $dstPath/read/DataPST.db /mnt/hmisql/
  25. Bonjour, Si le bouton google earth est inactif (gris) sur touareg (rns 850). Il est nécessaire de définir la valeur dans tb_intvalues DataPST.db 4 4117 1
