NOY
À propos de NOY
429 visualisations du profil
  1. Hello miazza, Do understand that the Internet is in your rns 850 to install the script diagnostics - diag 2.01. Then it is necessary install DataPST.db with car-net services.
  2. Yesterday I turned off the video on the move, street view is not work. The car is in the garage, I'm not going anywhere. I know that on the map exactly possible to view street view, I approached the card as close as possible, but I do not appear yellow man icon and I can not enter the street view mode. It should work well https://www.drive2.com/l/9263500/ What do these settings green menu Green menu nav/map Enable Satellite Images Dasable Satellite Images
  3. Hi, what should be the value of the trace/tracescope green menu, there is a suspicion that I have an incorrect value, so not working street view? https://mega.nz/#!TowyiArQ!lN-LYC-qTSe88aCQtlz29OocS8q-5vD9GSvPXAjyJAI
  4. pf.conf and nws.cfg are the same as in the script MMI-3GP-GE-WIFI.zip unchanged.
  5. Try to change the ip wifi openwrt at 192.168.2.1 and dhcp option to 3,192.168.2.1 as my photo above.
  6. According to the diagnosis of rns no internet, no ping sites. You have a built-in modem in rns 850 and wifi hotspot rns 850, try to connect to an access point wifi rns 850 to check whether there is the Internet.
  7. I made a photo as it works on rns 850 through a router mr 3040 openwrt, is not working street view and I still do not know why, on tmc online I think this problem can be solved. My gsm ISP blocks www.orange.fr so there is no ping. https://mega.nz/#F!D1pknRgS!OgcCv-zu-167G5tUo_utrw
  8. Hi, I noticed in the green menu in the nav/trafficonline line Connection Last Session just 32 characters - this value is 72057594037862402. was this idea that values 72057594037862401 this md5 hash vin, 32 characters is very similar to md5, as well as a password shadow. I tried to shove my vin in file and calculate a hash, but the values do not coincide with the ... 401 from my home DataPST.db And of course I looked sniffer wifi interface when tmc online worked, but I do not want to share this with everyone.
  9. The first message of this topic, script is called MMI-3GP-Diag-v2.01.zip After seeing your photos, I can not figure out whether there is Internet via gsm.
  10. In order to understand whether there is in rns 850 internet, I use a script (diag 2.01), it is in the cap threads. The script allows you to ping the sites of green menu rns. config Show IP Settings
  11. I looked at your photos, everything is right gemmi component is installed, the settings green menu right. Does have rns Internet, whether pings go to sites (diag v.2.01 - allows you to ping websites) config Show IP Settings show these photos If the Internet is in the exact rns to try again write.rar my script, and then press the button google earth.
  12. If you have router mr 3020 use this firmware openwrt - Peppy Snowdrop 2.3.2 http://acs-house.ru/files/firmware-mr3020-bp2-3-ps2-3-4gmodem/ or you can use GoldenOrb from ofmodemsandmen.com from 01.04.2016
  13. Try install fair mode again and restart rns Yes, language is English and you will see my list of radio stations. Other settings green menu should be in the MMI-3GP-odiconnect-v1.0.pdf Next, you should try to press the green menu googleearth install gemmi persistent, then restart rns. Do the following photo of green menu and show me. googleearth Get info gemmi diagnose/coding/internal_modules_1+2 diagnose/settings/tel_settings
  14. Regarding tmc online, I'm not saying that this is not possible, I have it worked until 30.05.2016 and i used audi values, and was blocked audi server. For tmc online requires a value 32783 in adaption channel 69 (vcds) or the value of 32783 to 40960 tb_intvalues file ​​DataPST.db And the correct values ​​in tb_stringvalues ​​DataPST.db file pst_is pst_namespace pst_key pst_value 6 676990753 72057594037862401 11111111111111111111111111111111 * Audi * DE 7 676990753 72057594037862402 11111111111111111111111111111111 72057594037862401 72057594037862402 values ​​and need to be taken from those who DataPST.db tmc online works. 72057594037862401 is coded vin 72057594037862402? See my DataPST.db in write.rar I used the values ​​and 72057594037862401 and 72057594037862402 audi of up to 3 years and I have worked tmc online 1 month.
  15. windstar, you should try to use my DataPST.db and see whether the active google earth, so we have chores. You can always return back to your DataPST.db via write the script. We must push install fair mode in the green menu. And what firmware version you have and maps ?
