Tout ce qui a été posté par Kill-R
Comment savoir quelle option de chassîs j'ai?
Kill-R a répondu à un(e) sujet de Kill-R dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
C'est la traduction littérale... donc je pense aussi. Je demande ça car j'aimerai monter des jantes 18" mais je veux savoir si ça va faire 4X4 ou pas trop. Car si je dois la rabaisser je met du 19 mais sinon j'opterai pour du 18. Qqun à des photos d'une s-line avec du 18 non rabaissée, juste avec le même châssis que le mien? -
D'après ce lien http://igorweb.org/equidec/Default.aspx voici ce que ça donne: E4J = "S-line" 7A0 = Without CD changer/CD player 4UE = Air bag for driver and front seat passenger 6XD = Exterior mirrors: electrically adjustable/heated 5SL = Left exterior mirror: aspherical 5RV = Right exterior mirror: aspherical 1KD = Disc brakes, rear J0R = Battery 380 A (80 Ah) 1LB = Disc brakes, front 1BV = Sports suspension/shock absorption 3FA = Without roof insert (standard roof) 5TG = Decorative aluminum inserts, dulling 7X0 = Without park distance control 4R4 = Power windows with comfort operation andcircuit breaker F0A = No special purpose vehicle, standard equipment 8GU = Alternator 140 A 0G1 = Gearshift lever 0YJ = Weight range 9 installation control only, no requirement forecast 0JG = Weight category front axle weight range 7 TB3 = 4-cylinder diesel engine 2.0 L unit 03G.B 3NZ = Rear seat bench unsplit, backrest split folding 8BB = Halogen headlight for driving on the right U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer X4B = National sales program Switzerland 1N1 = Power steering 1ML = Leather trimmed sports steering wheel 8Q1 = Headlight-range adjustment 9Q2 = Multi-function display/on-board computerwith check control 8Z5 = Not hot country D3X = 4-cyl. turbo diesel eng.2.0 L/103 kW 16VTDI with pump-jet injection system base engine: T9G/TB3/TM0/TP0/TC3/TD3/TQ0 7Q0 = Without navigation device CL6 = Alloy wheels 7.5J x 17 7K0 = Without tire pressure warning light 4X3 = Side air bag front with curtain air bag 2K1 = Reinforced bumpers 3L3 = Manual height adjustment for front seats 4KC = Side and rear windows in heat-insulatingglass 3Y0 = Without roll-up sun screen 4K4 = Radio remote controlled central locking 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz 1SA = Without additional engine guard 0GG = Emission standard EU4 Q1D = Sports front seats 4GQ = Windshield in heat-insulating glass -
Kill-R a posté un sujet dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
Tout est dans le titre, quel code option correspond au chassis sport S-line et autres... Et où je trouve ces infos sur ma voiture? Merci d'avance -
P'tit nouveau en A4 Avant B7 140 Sline
Le béquet est 90 euros la peinture peut-être autant et le montage c'est seulement de la colle car c'est une pièce en fibre creuse donc ça donne une qualité plus que merdique! En plus il à déjà fendu dans un angle :colere: franchement ça vaut la peine de mettre un peux plus pour avoir une pièce de qualité -
Voici 2 photos de l'ensemble faites avec mon portable... -
Pas besoin d'avoir peur, y a qu'a suivre le tuto pour demonter le pare-choc avant et après démonter les feux, pour le décollage des feux c'est 4min30 au four à air chaud à 150 et éteindre le four pendant que le feu est dedans, faut mettre le feu avec la glace vers le haut car sinon il passe pas dedans et ça évite de faire des traces de chaud sur la glace. Après faut séparer la glace en tirant dessus franchement, au moment ou il se sépare faut y aller franchement ça évite les bavures de colle pas facile à nettoyer. Mettre des gants avec revêtement anti-dérapant ça aide... Ensuite faut faire des trous dans le cabochon orange avec un fer à souder et dégager la base du cabochon pour arriver à le déformer en tirant calmement avec une pince à bec et il vient en un morceau. Penser à nettoyer les bouts de caches orange éventuellement pris sur la colle. Donner un coup de swiffer ou chiffon anti-poussière dans le feu et sur la glace pour être sûr... Puis rechauffer un léger coup la colle sur les 2 parties avec un foeun à décaper avant de replacer la glace sur le feu et remettre les clips en place autour du feu et voilà! Franchement c'est très facile à faire, faut juste prendre le temps... ;) -
Merci ;) J'ai aussi des bandes Ti rex mais je ne vais pas les mettres car l'intérieur des bandes est orange cuivré et ça se voit beaucoup c'est pas beau. Je pensais les mettre dans les feux et ensuite je voulais les mettre sous les feux dans le joint entre le par-choc mais les jeux ne jouent plus du tout et l'ajustage est mauvais. donc j'ai renoncé à les poser... -
Oublie, la bande est orange cuivrée à l'intérieur on voit que ça
Démontage pare choc avant
Kill-R a répondu à un(e) sujet de choum90 dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
Oui c'est normale que la traverse soit pliée à deux endroits symétriquement, la mienne aussi... -
Aujourd'hui je me suis décidé à enlever les caches oranges à l'intérieur de mes feux avant. J'ai monté des ampoules chromées à la place Voici ce que ça donne un fois remonté Et des photos de l'aileron et de la lèvre de pare-choc arrière -
J'ai tout pris sur le site shopping-tuning.com Mais à 9.90euros je m'attends pas à grand chose... Voici le lien direct si tu veux ces ampoules -
Hello, je profite de vous donner qques news de ma voiture.... Je viens de la récupérer après un grosse connerie de ma part, je me suis gouré de carburant à la pompe!!! J'ai pas encore reçu la facture du garage mais bon au moins j'ai pas eu de casse moteur, ouf! A part ça, j'ai posé mon bas de pare-choc arrière S-line ce qui fait qu'il ne me reste qu'à trouver les bas de portières et j'aurais le kit complet... Ce dimanche j'ai prévu d'installer mes ampoules de feux look xénon ainsi que les veilleuses à leds et ôter les caches oranges dans les feux avant. Mais aussi installer mes bandes Ti-Rex, je ne pense pas les mettre à l'intérieur des feux car je pense à la revente et je me dis que c'est pas ce que tout le monde préfère... -
becquet s line pour a4 b7 break
Kill-R a répondu à un(e) sujet de fred A4 dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
Faites gaffe car la qualité est plus que médiocre :unsure: -
Le béquet 85 euros sur ebay mais y a eu pas mal de job en carrosserie car c'est pas de la top qualité et le pare-choc 200 euros d'occase -
J'ai monté mon pare-choc S-Line ainsi que le béquet de toit. Il me reste juste à trouver l'écope qui se trouve dans la prise d'air de droite. -
Le parchoc est ainsi les anti-brouillards d'origine vont-ils? Je dois changer le capot aussi ou pas?
Bonjour, je me permet de reposter ma demande ici car j'aurais surement plus de chance d'avoir une réponse... J'ai trouvé un pare-choc Sline comme neuf pour 200Euros, que dois-je changer d'autre pour pouvoir le monter? Et les autres éléments du kit sont-ils disponibles en 2e monte? Merci de m'éclairer
Bonjour, j'ai trouvé un pare-choc Sline comme neuf pour 200Euros, que dois-je changer d'autre pour pouvoir le monter? Et les autres éléments du kit sont-ils disponibles en 2e monte? Merci de m'éclairer :coucou:
Je suis en Suisse donc c'est pas le même équivalent qu'en France -
Parechoc avant sline et installation spoiler sur A4 V6 TDI
Kill-R a répondu à un(e) sujet de hartge dans A4 B7 / A4 B7 Cabriolet - (2004 à 2007)
Merci mais celui-là je le connais, je cherche vraiment celui du kit Sline :malelovies: -
Hello, est-ce aussi possible de changer seulement le bas du par-choc avant pour y mettre un SLine sur les A4 B7? Si oui, avez vous les références, merci... :rolleyes: -
Je suis déçu de savoir que j'ai pas le kit Sline extérieur, est-ce possible de trouver les éléments qui le compose en 2ème monte? J'ai vu que le sujet à déjà été traité mais je ne trouve pas les messages, pouvez-vous me renseigner merci! -
Salutations à tous, je suis tout nouveau et prêt à adhérer au clan. Tout d'abord je voudrais vous adresser mes meilleurs voeux pour l'année à venir! Ensuite une petite présentation de ma belle: Il s'agit d'une A4 Avant 2.0 TDI 140 Sline de 2005 totalisant 60000km. J'ai pas beaucoup d'options et je connais pas bien les définitions des différents pack donc voilà une petite photo c'est mieux que des mots... Elle est équipée des jantes d'hiver en 16" mais dès ce printemps je vais monter les jantes des nouvelles RS4 :eldiablo:
Entre les seuils de portes, le volant et les broderies sur les sièges je crois que c'est bon... -
Ok ben zut je pensais avoir une Sline complet mais je te rassure c'est écrit partout dedans :bigsmile: Merci pour les infos des jantes, je ne sais que choisir...
