Seipold
Tout ce qui a été posté par Seipold
  1. Selon la maison AUDI la garantie seulement bonne pour perforation un troue en clair ... :colere:more photos from WWW.AUDIWORLD.COMPhotos de voitures j`ai pris de """"""
  2. ?Quelque un avec le meme probleme? voir photos. 2000 apg model a3
  3. If you change the Pierburg in the APG a3 model is difficult to pass the 077 air secondary test / readiness code you got 0000 1 000 that means that A. S. S can not work normal is :00000000 if all exhaust systems are OK. All the components are inter -related?? bon apetit.. AC_B520AC_20system_20electrical_20testing.pdf
  4. Info + vente + research+ XX Readiness_20code.pdf
  5. One you clik in the link google and later in the first in the page 69 of 90 you will see the info about maf Hitachi and Bosch (faire atention a pas melanger) merci .... PIERBURB_MAF.pdf
  6. The PIERBURG MAF : A 611 094 00 48 ~ 82 EUROS ,ask Mercedes garaje(demander un garaje Mecedes). The pin one is the temperature sensor,is the same that Bosch ,size,etc. Be careful Hitachi sensor have different pins ( ca va pas). The small problem I have still is the motor starting at low temperatures,the Pierburg Maf is very sensible at the antiretour air this is coming from the exhaust gases via the Egr valve, I push a little bit the pedal and OK. I saw that people that changed the Bosch for the Hitachi Maf, this is maybe better than the Pierburg maf ,changed the pins cables and un setpoint with the Vagcom tool in the adaptacion channel (the problem I have is the pin code 7 secrets numbers that the garaje keep secret). Hitachi maf is used in S4 cars. MOTRO_HITACHI_MAF___Cerca_con_Google.htm
  7. The APG motor a3 20v do not exist in the last list,maybe I am the first to test it (The MAF DEBITmetre). For people with interest in the Maf new technology Pierburg,this measure also the antiretour air and the intake temperature. The problems with A3 ,A4 ,etc. is also the EGR:n18 valve in my car ,the N80 valve from the gas tank,and the secondary air system in the cold start. If this valves are sending air ,CO,CO2,HC,H20,etc en the output of the MAF,this one get confused and the motor lambda goes very far from the ideal point (1) the car spend a lot of gas... if it is rich or lack of power ,like me with the Bosch alarm p1128 lean . What made me confused I am not mecanic is that the ECU bosch or the computer in the car takes command even with the Maf damaged (futu ) and the car runs with fixed air values speed dependent . Looks simple the MAF gives one voltaje from 0 to 5 volts full air M. But it takes a lot of technologie to do it right. Perdon for the French ,le clavier n`a pas les ``"";;;;;; MAF_FUNCIONAMIENTO2_PDFSOR_ANTI_PULSATION___Cerca_con_Google.htm
  8. C`est moi encore... a la page 45 on voi length : 7750 mm il y a un errer c`est : 7 ,7 microns : 0.00775 milimitres. Croiyez moi , et mon microscope de IBM. curiosite in chips: www.appliedmaterials.com see how the chips are made. PIERBURD_DOS_PDF_INteresants.htm Star_Trek_The_Next_Generation_Episode_MUS3.htm achievements_and_results_annual_report_2003_pierburg_wafer___Google_Search.htm
  9. Apres ouvrir the Pdf link achiv...2003.. regarder svp pages 43-44-45 on verra le silicon sensor debitmetre . 0ne micron is 0,000.001 metre = 0.001 mm plus ou moins is 7 microns longeur largeur ,rien de tout.. excusez la ecriture j`ai ne suis alle a l`ecole
  10. MAF pierburg is coming from a new generation silicon wafer sensors 2002. made in IBM paris Corbeil. bon apetit..
  11. dicionaire: INGLISH FRENCH SPANISH MAF DEBITMETRE CAUDALIMETRO HOLE TROU AUJERO BOSCH ROBERT ROBERTO PIERBURG MARQUE MAF CAUDALIMETRO DE mercedes. army arme GABACHOS(NAPOLEON). ICI ON PARLE FRANCAIS. Le debitmetre marque Pierburg mesure l`air miex que le Bosch.
  12. C`est le s4 mais presque .. parent directory et apres tu vas a dif. livres en inglais mais pas dificil. B5_CUATRO01_Fuel_injection_and_ignition_AWM_MFI.htm FRENOS.htm criss_angel_levitation.htm
  13. TESTING ? PARENT DIRECTORY S4
  14. le dernier :Bosch ici avec un trou ??? la foto vien de ?? foro internet.
  15. Le MAF Pierbug marche in the APG moteur ,le meme conecteur. ?avant avec le BOSCH la A3 avais le erreur Vag p1128 system lean -peuvre en air-, ? aussi le repris a monte...
