fennec
Utilisateur Novice-
À propos de fennec
Prénom
Fennec
Aquitaine
A6 C6 4F Avant Avus
Motorisation
V6 3.0
conseil achat A6 avant 2,7 tri avus
fennec a répondu à un(e) sujet de gaiko dans A6 C6 / A6L C6 / allroad C6 - (2005 à 2011)
E0A = No special edition 7MG = Emission standard EU5 4UF = Drivers and front passenger air bag with front passenger air bag deactivation 6XK = Exterior mirrors: automatically dimming,electrically foldable/adjustable/heated 5SL = Left exterior mirror: aspherical 5RU = Right exterior mirror: convex (large viewing field) 1KD = Disc brakes, rear J0Z = Battery 520 A (110 Ah) 1LG = Disc brakes, front 1X0 = Front wheel drive 1BA = Standard suspension/shock absorption 3FE = Electric slide/tilt sunroof with sun screen/sunblind 5TE = Decorative aluminum inserts 7X4 = Park distance control, front and rear 4R4 = Power windows with comfort operation andcircuit breaker F0A = No special purpose vehicle, standard equipment 8GV = Alternator 180 A 0G7 = Tiptronic 0YJ = Weight range 9 installation control only, no requirement forecast 0JM = Weight category front axle weight range 12 TA1 = 6-cylinder diesel engine 2.7 L unit 059.F 3NZ = Rear seat bench unsplit, backrest split folding 8BP = Bi-functional headlight with gas discharge lamp U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer X3A = National sales program France 1N3 = Speed-related variable steering assist (Servotronic) 2ZQ = Leather trimmed multi-function steering wheel for air bag system 8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving) 9Q4 = Multi-function display/on-board computerwith check control 8Z5 = Not hot country D4V = 6-cyl. turbo dies. eng. 2.7 L/140 kW 24VV6 TDI, common rail base engine is TA1/TH1 7T6 = Navigation system (MID) CD3 = Alloy wheels 8J x 18 7K0 = Without tire pressure warning light 4X3 = Side air bag front with curtain air bag 2K1 = Reinforced bumpers 3L5 = Electric seat adjustment for both front seats 4KC = Side and rear windows in heat-insulatingglass 3Y3 = Roll-up sun screen for rear window and rear side windows 4K4 = Radio remote controlled central locking 5D7 = Carrier frequency 868 MHz without panic button 1SA = Without additional front underbody guard Q1A = Standard front seats 4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number Ca semble confirmer les infos que tu as : On dirait qd même bien une avus. Provenance France Retros electriques rabattables Toit ouvrant électrique (option) Stores dans les portes arrières et lunette arrière (option) 2,7 L, Traction Xenon Tiptronic Sièges électriques Radars de recul avant et arrière -
Nouvelle A6 Avant
fennec a répondu à un(e) sujet de fennec dans A6 C6 / A6L C6 / allroad C6 - (2005 à 2011)
Je suis admiratif mais c'est pas mon truc. J'aime bien bricoler mais pas ça ... Avec 3 planches et un vieux PC je suis plus à l'aise, je fais ça par exemple :http://mycabinet.free.fr -
Nouvelle A6 Avant
Je suis trop nul en photos mais je vais essayer !!!! Pas de modif en prévision je suis un adepte du full origine -
Nouvelle A6 Avant
Rhoooo, pas objectif en plus !!!!! Il est vrai qu'on en voit quand même pas mal de cette couleur, mais elle a des aventages : On voit moins les sallissures et les petits défauts (ce que du noir ne pardonne pas !) Elle ne vient pas d'un paticulier c'est un véhicule de direction. Cool alors tout est normal :marcelpoire: -
Bonjour à tous, merci à tous les contributeurs pour cette mine d'informations !!! Le savoir n'a d'intérêt que s'il peut être partagé ... Je viens d'acquérir une A6 avant 3.0 en finition AVUS de Octobre 2009 avec 60 000 Kms. Je joins une photo, qui n'est pas la mienne mais c'est la même. (j'essaierai d'en faire lorsqu'il fera beau) J'ai eu des véhicules avec boite auto depuis 2000 et j'ai voulu changer, non pas pour le confort au quotidien (là il n'y a pas photo) mais pour la longévité et/ou les coûts de maintenance en cas de pb et la conso un peu moindre Bref, je "zieutais" les annonces depuis un moment et j'ai trouvé ! J'ai couru chez Audi recroiser les infos que j'avais et les leurs et tout matchait ! C'est donc une 3.0 Avant Quattro finition AVUS boite manuelle avec je pense pour seule option les sièges conducteur et passager à mémoire, mais l'équipement "de base" est plutôt fourni ! J'ai fait depuis 7000kms et j'en suis ravi. Le confort et l'insonorisation sont bluffants. Le moteur est très agréable et je trouve les premiers rapports un peu courts. (Peut être mes 14 ans de boites auto ...) J'ai fait Bordeaux -> les Angles soit 1200 Kms aller-retour en faisant du 6,4L de moyenne sans y aller à l'économie. Un tel moteur associé à cette conso me convient parfaitement. Contrairement à des nombreux commentaires négatifs, l'éclairage Xénon ne m'a pas perturbé, seul le MMI utilise une logique qui n'est pas la mienne. Pour les fonctions de base pas de problème mais dès qu'il faut checher une option "inhabituelle", j'y passe un peu plus de temps ... Un petite question tout de même : Qand se déclenche le message "Faire le plein" chez vous ? Sur la mienne c'est lorsque l'autonomie restante est à 70km. Comme je l'attendais à 100km je pensais que ça ne fonctionnait pas au début. Ma liste de codes option : Usine d'assemblage : Neckarsulm - Allemagne Date de sortie d'usine : 02/10/2009 Année Modèle : 2010 Type Moteur : CDYC > 2967cc TD - Common-Rail - 176kw (239cv)Recherche de pièces Type Boite : JMJ Code couleur : Q4 > gris quartz metallise (LY7G)Equipements (Numéros PR) : 0F3 Systeme d'alimentation en diesel 0FA Cycle de fabrication standard 0G1 Levier de changement de vitesses 0HP Differenciation des classes de vehicules 4F0 0JM Classe de poids essieu avant plage de poids 12 0LJ Avec plaques/autocollants/certificats de securite speciaux pour la France 0M5 Reservoir a carburant 0N5 Essieu arriere standard 0P0 Tubulure arriere d'echappement a l'arriere (standard) 0ST Autocollants/plaques, allemand-francais 0TD Tapis de sol a l'avant et a l'arriere 0U2 Qualite du carburant < 50 ppm 0VB Documentation de bord en francais 0W1 Autocollant pour systeme electrique central, pays de langue allemande 0YK Plage de poids 10 seulement numero de controle pour pose pas de prevision des besoins 1BA Suspension/amortisseurs standard 1C1 Antigel jusqu'a -25 degres Celsius tolerance jusqu'a -30 degres C 1D0 Sans dispositif d'attelage 1EX Plaque du constructeur speciale pour CE pour voiture de tourisme M1 1KW Freins a disque a l'arriere 1N3 Direction assistee, en fonction de la vitesse (Servotronic) 1PD Boulons de roue avec ecrous antivol (ne fermant pas a cle) 1S1 Outillage de bord et cric 1SA Sans plaque de protection supplementaire sous le moteur 1T3 Trousse de secours avec triangle de presignalisation 1VH Pieces pour moteur 6 cylindres 1X1 Toutes roues motrices 1Z2 Augmentation du premier remplissage en carburant de serie 1ZL Freins a disque a l'avant 2C5 Colonne de direction, reglable axialement et verticalement 2D0 Sans carenage aerodynamique 2K1 Pare-chocs renforces 2WA Sans pneus supplementaires 2Z0 Suppression du nom de modele (desiglage) 2ZQ Volant sport cuir pour systeme d'airbag avec tiptronic et logo S d'airbag 3B4 Ancrage pour siege-enfant systeme ISO FIX 3F4 Roue de secours avec pneu normal 3FA Sans trappe de pavillon (toit standard) 3G2 Ancrage pour siege-enfant a l'avant a droite (ISOFIX) 3GD Plancher de chargement plan a l'arriere 3LD Revetement de porte et lateral 3M3 Version voiture de tourisme 3NZ Banquette arriere non divisee, dossier divise et rabattable 3PN Reglage electrique des deux sieges avant avec memoire 3Q1 Appuie-tete a l'arriere 3S1 Barres de toit en metal brillant 3X0 Sans fourreau 3Y0 Sans store pare-soleil 4A0 Sans siege chauffant 4E0 Deverrouillage hayon/capot arriere de l'exterieur 4GP Pare-brise, verre athermique avec bande de couleur et regard pour numero de chassis 4H5 Securite-enfants, commandee electriquement 4K4 Verrouillage central avec radiocommande 4KF Glaces laterales en verre athermique, a partir du montant central et a l'arriere teintees sombre 4L6 Retroviseur interieur de securite reglage jour/nuit automatique 4R4 Leve-glaces electriques, avec commande confort et limiteur de force 4UF Airbag pour conducteur et passager avec desactivation de l'airbag du passager 4W0 Sans logement pour cassettes/CD 4X3 Airbag lateral a l'avant, avec airbag de tete 4Y0 Sans vide-poches/compartiment de securite 4ZB Baguettes enjoliveuses en metal brillant 5A5 Habillage du coffre a bagages avec vide-poches 5C0 Sans mesure particuliere pour la carrosserie 5D7 Frequence porteuse 868 MHz sans touche de panique 5J0 Sans spoiler arriere 5K5 Film de protection pour le transport, avec mesures de protection supplementaires pour le transport 5NH Dispositif de levage du hayon 5P0 Sans dispositif de fixation pour bouteille d'oxygene 5RU Retroviseur exterieur droit, convexe (grand champ de vision) 5SL Retroviseur exterieur gauche, aspherique 5TE Applications decoratives, alu 5XC Pare-soleil, avec miroir de courtoisie eclaire cote conducteur et passager 6E3 Accoudoir central a l'avant 6F0 Sans pellicules decoratives/logos 6FA Composants sans surface particuliere 6M1 Araignee a bagages 6NJ Pavillon moule standard 6SS Garniture de plancher du coffre a bagages 6U0 Sans joint supplementaire a l'exterieur 6V1 Tole de garniture a l'arriere (ECE) 6W5 Support de plaque d'immatriculation a l'avant 6XL Retroviseur exterieur avec fonction memoire, reglage jour/nuit automatique, rabattable/reglable/degivrant electriquement 6Y8 Dispositif de limitation de vitesse 7AL Systeme d'alarme antivol, dispositif de surveillance de l'habitacle, Back-up- Horn et protection antiremorquage 7B2 Prise 12 volts dans le coffre a bagages 7D5 Lecteur de DVD 7F9 Pommeau/poignee de levier de vitesses en plastique / cuir 7G0 Sans preparation pour VTS (systeme de suivi de vehicule) 7K0 Sans controle de la pression de pneu 7M1 Baguettes de seuil dans les baies de porte avec application de metal 7MG Depollution, EU5 7P1 Appui lombaire, reglable electr. dans les dossiers des sieges avant 7QA Sans CD/DVD pour la navigation 7T6 Navigation system (MID) 7X4 Park distance control, front and rear 7Y0 Without lane change assistant 8BP Bi-functional headlight with gas discharge lamp 8GV Alternateur 180 A 8K9 Separate daytime running lights with low beam assistant and Coming Home function 8N6 Windshield wiper intermittent control with light/rain sensor 8Q3 Automatic headlight-range adjustment dynamic (self-adjusting while driving) 8SK Taillight assemblies with diodes (LED) 8T1 Cruise control system (CCS) 8TF Rear fog lights, left and right 8X1 Headlight washer system 8YQ Radio HIGH 8Z5 Not hot country 9AQ Air conditioning plus 9LA Without rotating emergency lights 9M0 Without auxiliary/parking heater 9P3 Seat belt reminder, electric contact in buckle 9Q4 Multi-function display/on-board computerwith check control 9VD Speaker (active) 9WC Without Multimedia in vehicle 9ZF Mobile phone preparation with hands-freespeaking system A00 No self-collection A51 Audi AG A8S Standard equipment AQ0 Standard-production quality AV1 Driving on the right B08 Pays avec homologation de type France B0A Jeu de composants sans prescriptions nationales de fabrication C23 Operating permit, alteration CD3 Alloy wheels 8J x 18 D50 6-cylindres moteur turbo diesel 3.0 l/176 kW 24VV6 TDI, common rail - Base moteur : T41/TE1/TF1/TH1 E0A No special edition EA0 Without subsequent warranty EW0 Without maintenance contract F0A No special purpose vehicle, standard equipment FA0 Control of standard production FC0 Without customized installation FM0 Basic equipment variant FQ0 Standard production wheels G0L 6-speed manual transmission for four-wheel drive vehicle GP1 Vehicles with special upgrade measures GZ0 Manually operated doors HE6 Tires 245/40 R18 Y J0Z Betterie 520 A (110 Ah) K8D Station Wagon Variant/Avant L0L Left-hand drive vehicle N5W Leather seat covering NM1 Engine cover NT0 Transit coating (type 1) NY0 Standard Betterie/Alternateur capacity PAH Option non connue actuellement dans la base PRK Option non connue actuellement dans la base PV6 Option non connue actuellement dans la base Q1A Standard front seats QE1 Tray areas package 1 QF0 Without receiver (car phone) QH1 Voice control QQ1 With additional lights (interior lighting) QV0 W/o TV reception/digital radio reception QW1 Central controL Moteur, front T41 6-cylindres moteur diesel 3.0 L Moteur 059.D U1A Instrument insert with km/h speedometer,clock, tachometer and trip odometer UF7 Electric interface for external use V0A Tires w/o specification of tire brand VC0 W/o remote-controlled garage door opener VX0 Without hands-free system VY0 Without danger alarm system WAF Option non connue actuellement dans la base
