Arkhia
Tout ce qui a été posté par Arkhia
  1. Arkhia
    Commande A5
    Récap pour me faire plaisir :eldiablo: :eldiablo: :eldiablo: :eldiablo: A5 S-Line V6 2,7L TDI DPF 190CV Multitronic Couleur : Noir Brillant A2A2 Intérieur : Noir Surpiqures Noires Cuir Alcantara N7K QE Châssis Sport S-Line 1BV Options : Rétroviseur Intérieur Jour Et Nuit 4L6 Rétroviseurs Extérieurs Rabattables, Dégivrants et Jour Nuit Auto 6XK Volant Airbag Multifonction Avec Palette 2FQ Phares Xénon Plus PX4 Système I Pod (AMI) 7D3 Radar De Recul 7X4 Téléphone 2 Watts dans l’accoudoir PT5 Pack Eclairage QQ1 Trappe à Ski 3X2
  2. Arkhia
    Commande A5
    nice
  3. Arkhia
    Clim auto
    trouvé mais commandes non MMI
  4. J - 4 ... semaines pour ma voiture.... :eldiablo: :eldiablo: :eldiablo:
  5. Arkhia
    Commande A5
    S4 - S1 = 3 semaines.... suis comme un gosse il ont interret à la teleporter une fois produite ;)
  6. Arkhia
    Tips'n Tricks
    Allez j'commence mais en anglais ;) So after some experimenting with FinallyS5's car last weekend, we have confirmed with Roswell'S5 car that these settings indeed work. For your reference, here are some screen prints from today's coding session with Roswell'S5. First connect the VAG COM cable to the car, which is tucked WAY up above the deal pedal...I've hooked up the VAG COM to scores of cars, and this was by far the MOST difficult to access of all VAG products. Dash is so deep, and Audi did not bring the connector forward enough. Activating the voice command button Once hooked up and connected to your laptop, turn the car to the accessory position (engine does not need to be running) and open the VAG COM program (I used beta version 711.0). Select the Electronics 1 tab, 2nd from the right: Open module 77-Telephone (middle of 3rd column): When the controller is open, you will see the default code set at 0010900 which is the factory setting, with voice control OFF. Chose Coding-07 to open the recoding window: The coding window should have a nice reference "bubble" for codes: The 2nd to last digit should be changed from 0 (Voice Control OFF) to 7 (English (USA)), so we changed from 0010900 to 0010970: Once you have changed the code, click "Do It!" and you will receive confirmation that the code was accepted. Close this controller. You are done. It took a few restarts of the car (and systems) before the voice button on the steering wheel activated. Folkie mentioned in an earlier post that you can go into the CAN Gateway, select "Installation List" and click "Save" and it should work, but we tried and it did not immediately activate. Deactivating the seatbelt chime From the VAG COM Common tab screen, select Instruments - 17: Click Coding -07: The instruments have long coding, which requires you to open the long coding helper instead of a bubble window for reference. Click on the Long Coding Helper button: You'll see a check box that shows that the seatbelt warning is active. Click on the check mark to remove it, the click "Transfer Coding: You'll see the long coding transfeered to the New coding window ("8B" changed to "83") Click Do It! and youll see the coding was accepted: Your are now seatbelt chime free, but for goodness sakes WEAR YOUR SEATBELTS!!! la suite du site Ross Tech Operating Windows and Sunroof with Remote (Note, the sunroof cannot be opened with the remote) You need to continuously hold the remote button for the function to operate. [select] [46 - Cent. Conv.] [Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in line 3) and you'll see the selectable options below. Check the box for "Comfort Operation: Remote Control active" [Transfer Coding] [Do It!]
  7. Arkhia
    Clim auto
    quelqu'un aurait t il une photo de la clim monozone???
  8. Arkhia
    Modèle de tel
    mon nokia a moi testé dans une A6 fonctionne pour tel mais peu de fioritures... il faut installer un soft sur le tel (E61) pour qu'il y est une synchro du répertoire mais il est noté comme incompatible dans la notice allemande
  9. Update 2nd January 2008 The next factory build week confirming – week 06/08 (week 06/08– week commencing 4th February 2008). A5/S5 Coupe – Revised Information Revised Information • Availability of the panoramic sunroof is reduced due to production constraints and has therefore been removed from ordering until further notice. • The 1.8T engine has been re-opened for ordering. • S5 lead time is currently showing April as production is full up to that time. As a result Centre tagged cars have been locked to allow customer cars to be scheduled. • Scheduling of 2.7TDI multitronic has been revised and lead times for this engine should be calculated as early May 2008 for customer orders due to vehicles taking 5 weeks in addition to the scheduled build week to be completed. Previous Information • Please note that Black headlining is only available with upholstery colours GD or GG with Sports seats and only with GD on standard seats (26/09/07). Google Translate - Mise à jour 2 Janvier 2008 La semaine prochaine usine construire confirmant - semaine 06/08 (semaine 06/08 -- Semaine du 4 Février 2008). A5/S5 Coupé - révisé information Renseignements révisés • Disponibilité du toit ouvrant panoramique est réduit en raison de contraintes de production et a Donc été retiré de la commande jusqu'à nouvel avis. • Le moteur 1.8T est de nouveau ouverte pour la commande. • S5 de temps est affiché actuellement avril, la production est plein jusqu'à ce moment-là. À la suite Centre tagged voitures ont été bloqués de manière à permettre à la clientèle des voitures à programmer. • Planification des 2.7TDI multitronic a été révisé et les délais pour ce moteur Doit être calculé en début du mois de mai 2008 pour les commandes des clients en raison de véhicules prenant 5 Semaines de l'horaire construire semaine à être complété. Previous Information • S'il vous plaît noter que Black tête est uniquement disponible avec sellerie couleurs avec GD ou GG Sports Sièges et seulement avec GD standard sièges (26/09/07). Je ne sais pas ce que ça vaut mais ça fait peur...
  10. Très belle voiture et très jolies jantes.... Apparement tu as fait un glass teint ou autre dans la région bordelaise, pourrais tu me donner un tarif approx et ta satisfaction / l'endroit ou tu l'a fait faire? Merci d'avance
  11. Arkhia
    Modèle de tel
    le support je l'ai acheté 60 euros sur le forum ;) sinon 200 chez Audi environ
  12. Arkhia
    Modèle de tel
    Parce que ton tel est en 2W et qd tu roule ton Antenne ext est en 8W => qualité de réception bien supérieure + éviter les aléas blutooth Pour le blutooth, la seule contrainte est le SAP Mais non je n'ai pas été "obligé", je préfère avoir un 2d tel...
  13. Arkhia
    Modèle de tel
    pour la liste.... ya rien de moderne Ce que j'ai fait : achat d'un tel secondaire + support + carte jumelle (100euros le pack + 11 euros par mois pour la carte) Parce que si tu veux un tel qui marche bien il faut le transformer en 8w et donc le mettre dans un support pour utiliser l'antenne extérieure. Sinon en blutooth, il faut un tel qui supporte le SAP pour à minima avoir la synchro du répertoire (Sim Access Profile) Nokia le fait mal pour info Appelle moi si besoin de plus ;)
  14. Arkhia
    Assurance
    ouais ben a part mnsieur le doc c'est à peu près pareil ( 1,5 fois ) pour les trajets pros...
  15. Arkhia
    Assurance
    et tu est en trajet pros aussi??? pitain j'aurais du faire doc...
  16. Partageons le savoir ;) Pour l'instant je suis proche de l'illettrisme :coucou:
  17. C'est le père noël.... Moi il a du retard ce .......
  18. Salut a tous, je viens d'appeler mon assureur (Matmut) et il me propose un tarif de 1350 roros annuels sachant que je suis en trajets pro :) Pouvez vous me donner une estimation de vos tarifs pour comparer? Merki PS A5 11cv 2,7 TDI
  19. Arkhia
    Commande A5
    J'espere fort que sera pareil pour les 2,7 .... :eldiablo: Mais fo pas rêver... Plus que 4-5 semaines.... :rolleyes:
  20. Arkhia
    Bruyante, la A5 ?
    moi j'ai testé un 2,7 et un 3 l jusqu'à 140 - 150 c'est très silencieux Après on commence à entendre certains bruits (roulement, vents) mais c'est vraiment peanuts ;) Par rapport à mon mazout d'A3 en 17'
  21. Arkhia
    Commande A5
    bon ben c mort alors... <_<
  22. Arkhia
    Commande A5
    bon et ces photos ;)
  23. Arkhia
    Commande A5
    VIIIIIIIIIIIIIIIIIIITTTTTTTTTTTTTTEEEEEEEEEEEEEEEEE ;)
  24. Arkhia
    Commande A5
    il manque comme des photos....
