d1ufo
Tout ce qui a été posté par d1ufo
  1. Tested now again without the 4G modem connected to the router and now it is not working. So I assume it i a Router (bricked or faulty?) or a MMI Problem. So would be nice if you could tell me how i set the gateway manually in the MMI and I think that will solve everything. :-)
  2. I think we got the solution. How do I set the Gateway in the MMI manually? Because I don't need the hotspot of the MMI because I have a stick "Huawei E8372" with built in Hotspot so the intern WIFI of the MMI i don't need. No, the FW was installed weeks ago. :-) I tried connecting first the router (without the stick in the router) and I got "default -> 192.168.1.254". And then I inserted the stick into the router. I will try this procedure tomorrow again and then I can tell you if it worked. So if it works tomorrow the I assume that the problem is maybe in the power consumption of the stick (Y-Cable?). So we will see. But pse. tell my how i manually set the gateway in the MMI. Thanks
  3. Maybe this can help you. It is the whole package i use to install everything. https://we.tl/wp7UzzcuuF
  4. The gateway 192.168.1.254 is already there in my router under Interfaces -> wifi -> DHCP, a said that i have done every step carefully like in the tutorial. The error in the english version i saw it when i did the programming of the router. everything is ok. Maybe is something wrong in this picture? https://img4.picload.org/image/rdddgrga/img_6327.jpg So now i deinstalled the patch and installed it again. After that i applied the k900 patch because my MMI Software is K900. Here is the log file from the first patch (before the K900 patch): http://pastebin.com/M5FDuEY6 Believe me it confuses me so much because sometime it works and sometime it does not. And the really weird part is that i don't make anything in the settings of the router nor mmi, only driving :-)
  5. Now I looked up, its working but the green menu got strange: https://picload.org/image/rdddddgw/img_6332.jpg https://picload.org/image/rdddddrr/img_6333.jpg
  6. It is in both cases the same as in the pictures i sent you. Thats really weird I know, but there is no change in the green menu when it is ok and when not ok.
  7. I did everything what was in the tutorial. The one which is in french and englisch. What settings are missing, can you pse. send me? The funny part is, with this setting, never touched a few days ago, yesterday evening it worked, today in the morning it didn't and now it works. But I need a 100% solution and setting to work every time.
  8. Hi Frankie, yesterday I tested again and somehow it worked. BUT, today it doesn't work. Had it often so and I didn't change any setting in MMI or in the Router. - when I plug my laptop in the router via LAN interface I always get internet. - see picture attached, I can't ping 192.168.1.1 - screenshots are attached. https://picload.org/image/rdddggpl/1.png https://picload.org/image/rdddggpi/2.png https://picload.org/image/rdddggpw/3.png https://picload.org/image/rdddggwr/4.png https://picload.org/image/rdddggwa/5.png https://picload.org/image/rdddggwl/6.png https://picload.org/image/rdddggwi/img_6324.jpg https://picload.org/image/rdddggww/img_6325.jpg https://picload.org/image/rdddgrgr/img_6326.jpg https://picload.org/image/rdddgrga/img_6327.jpg https://picload.org/image/rdddgrgl/img_6328.jpg https://picload.org/image/rdddgrgi/img_6329.jpg https://picload.org/image/rdddgrgw/img_6330.jpg
  9. Bonjour and hi everyone, I have installed the scripts, set up the router as described in the tutorial but connect online is not working. I have a compatible stick, under interfaces the internet is working and the mmi i think is connected to the router but in green menu under ip config it says that it is not connected. I am really confused. Can somebody help me?
