congo
À propos de congo
816 visualisations du profil
  1. Cool, glad that it worked for you :) If you do find the map please share. As for the activator. the one for the EU maps should for for AN map too ;)
  2. Cant tell you. Don't have such MAP in hand to try :(
  3. You need K0821 in order GE to work. But i don't have AN map so use at own risk :) Second - why you are using the Odi WIFI scripts when you have SIM ... not the same. For car with SIM you only need 02 - RNS850-GE_ENABLE but that will work on RNS units with K0821/2 soft.
  4. @frankiegom MyAudi access - access to some online info should be working on your unit (A6/4G) if it's MMI 3GP and have SIM slot. For the traffic online cant tell you much as here in Bulgaria we don't use it as it's useless. If your unit have SIM slot you can ask your local Audi dealer as there is some fee if the vehicle is more than 3 years old. Currently all other solutions are not working, but i believe that the fee is no more than 50-80E per year which i believe is not so much money :) As for the help - i will try to help you with what i know and can but my time is limited .... this is just a hobby for me and as it turned out there are some people that i've helped and then they spit you in the face. Cheers.
  5. Yep French sorry . About the sqlite.xml, yes it is possible.
  6. You will have answer soon. I'm doing some more debugging till the end of this week and will post some of the findings. Unfortunately i'm not good with Italian, do you know if i can change the language of the forum interface to English?
  7. Confused, since when you have BG radios on Russia ? CITYBG RADIO RADIO 1 bTV radio ENERGY ROCK FRESH Z-ROCK STAR FM CHEAP VERONIKA FM+SOFIA VITOSHA CITY NovaNews BULGARIA ANTENA BNR SOFIA CLASSIC105 FM ... these are all BG radio stations. NOY i believe you know me well and we have done some great work past 3 months. But why you ignored my advise not to publish MY datapst.db until i work-out the exact values for all the options? As you know i've spend great amount of time on something that is not ready to be published. I'm fine with people using it but no posted on forums that are visible from google. I've shared everything with you in exchange of collaboration and not money right ? :mur: p.s. Just to warn people that use the solution is it is. I had one case that i had to re-flash the unit using serial connection. Why - i still don't know. One out of three with that datapst.db died. That is not a problem for me because i can fix it but it could be problem for you .... Just to know.
