Tommyknocker
Tout ce qui a été posté par Tommyknocker
  1. Comme nous l'avons déjà dit ... c'est toujours un plaisir de lire vos guides! Merci! As previously said...it's always a pleasure reading your guides! Thanks!
  2. bonjour, je voudrais remercier Etry pour son guide et son aide précieuse. hello, i would like to thank Etry for his guide and his precious help. Inviato dal mio iPad utilizzando Tapatalk
  3. some people in various forums tried to code it but with no success. A guy on an italian forum says it's a different software, it's not a question of coding. good news apparently he's in touch to try a software update to see if it's working. certaines personnes sous diverses formes ont essayé de coder mais sans succès. Un gars sur un forum italien dit qu'il est un logiciel différent, ce n'est pas une question de codage. bonnes nouvelles, apparemment, il est en contact pour essayer une mise à jour du logiciel pour voir si cela fonctionne.
  4. In Rome, Italy, unfortunately not a friendly place for 19'' 's............ :unsure: à Rome, en Italie, malheureusement pas un endroit très sympathique pour 19 '' ........... :unsure: Thanks! Merci! Merci Etry, il gagnera plus avec le bon ensemble de palettes: lol:
  5. hopefully it's not an hardware limitation, would be nice to compare adaptations with a factory installed one. il est heureusement pas une limitation matérielle, serait bien de comparer les adaptations avec une usine installée un.
  6. ok, make sense the controller senses the pads disconnect and reconnected. Thanks again Erty for your help, you convinced me to do this up. Only thing i need now is a couple of pads :icon_lol:, i would like to spend no more than 100€ also considering the fact we do not use the electronics. Price proposed by Audi is astronomical. i'll start searching and proposing offers on ebay. really appreciate your help!
  7. Thanks so much for your help Erty, much appreciated. Don't kill me last question, promised, what was the fault code afterwards and was it resettable ? Thanks again for you time! Merci beaucoup pour votre aide Erty, très apprécié. Ne me tuez pas la dernière question, promis, ce qui était le code de défaut après et était-ce réinitialisable? Merci encore pour votre temps! Inviato dal mio iPhone utilizzando Tapatalk
  8. I'll give a look! Inviato dal mio iPhone utilizzando Tapatalk Thanks!!! Inviato dal mio iPhone utilizzando Tapatalk
  9. ok that's very interesting, since after the first coding, traffic signs rec works and the item is present in the menu, problem is that it'is greyed out and if you click it system is reported as not available even if it's working fine. as soon as you change Car_Function_List_BAP_Gen2-menu_display_road_sign_identification_0x21 the item disappears from the mmi menu but traffic signs keep working fine. just curious if having the menu on is just a question of setting up proper adaptations. curious if about 152 - 154 -155 adaptations are on on factory equipped cars... hope I'm not annoying you with this cross thread interrogation! ok ce qui est très intéressant, car après le premier codage, des panneaux de signalisation de travaux rec et l'élément est présent dans le menu, problème est que IT'IS grisée et si vous cliquez dessus système est signalé comme non disponible, même si ça fonctionne bien. dès que vous changez Car_Function_List_BAP_Gen2-menu_display_road_sign_identification_0x21 l'élément disparaît dans le menu mmi, mais les panneaux de signalisation garder fonctionne bien. simplement curieux si avoir le menu est juste une question de mettre en place des adaptations appropriées. curieux de savoir si environ 152-154 -155 adaptations sont sur les voitures d'usine équipée ... espère que je ne suis pas vous ennuyeux avec cette interrogation de fil croix!
  10. that's great,do you think that this change is reversible, it's possible to put back the original ones? and other couple of questions sorry... :langue: so without the metal shaft it works fine exactly like the original one? the +/- are lighted red like on the original ones? when dismounting the air bag did you cut the battery off or left it on? off course with no obligation at all any chance to make more picture of the upgrade? Hope I've not be too invasive with all these questions... qui est très bien, pensez-vous que ce changement est réversible, il est possible de remettre les originaux? et d'autres quelques questions désolé ...: langue: sans le métal arbre il fonctionne très bien exactement comme l'original? le +/- rouge sont éclairés comme sur les originaux? Lors du démontage du coussin gonflable ne vous coupez la batterie hors tension ou à gauche sur? bien sûr, sans aucune obligation à tous une chance de faire plus d'image de la mise à niveau? J'espère que je ne l'ai pas être trop envahissante avec toutes ces questions ...
  11. Hello Everybody, A question about Traffic sign recognition, when you guys coded this function do you have it on the MMI menu? we were trying with a friend to have both the function and the menu active, but with had no luck. if anybody got both, is it possible to have the exact sequence of coding? or if not, anybody who has traffic recognition from factory willing to send all the 5F Adaptations? it is possible to save all the adaptations of a single controller very easily with the vag. thanks for the help!!! bellow i translated the message with goggle, sorry i don't speak French :shakehead: !!! Bonjour tous le monde, Une question sur le trafic signe de reconnaissance, lorsque vous les gars codés cette fonction avez-vous sur le menu MMI? nous avons essayé avec un ami pour avoir à la fois la fonction et le menu actif, mais avec pas eu de chance. si quelqu'un a obtenu à la fois, est-il possible d'avoir la séquence exacte de codage? ou sinon, quelqu'un qui a la reconnaissance de la circulation de l'usine prêts à envoyer tous les Adaptations 5F? il est possible d'enregistrer toutes les adaptations d'un seul contrôleur très facilement avec le vag. Merci pour l'aide!!! ci-dessous i traduit le message avec goggle, désolé, je ne parle pas français :shakehead: !!!
  12. bonjour, very interesting topic. just few questions, now when you change shift with the paddles do you still have the click from the button? and about the metal shaft not fitting is that a structural item or is just a mechanic stop to keep the electronic in place? last i tried to look for this item in Audi and all they have is the super gloss black (4S0951532A) anybody knows if a satin version is available? anyway very interesting guide indeed. thanks ps unfortunately i don't speak Franch i translated using goggle, hope i didn't say anything embarrassing! ps malheureusement je ne parle pas français i traduits en utilisant Google, espère que je ne dis rien embarrassant! Bonjour, sujet très intéressant. à quelques questions, maintenant, quand vous changer changement avec les palettes avez-vous encore le clic du bouton? et autour de l'arbre de métal ne correspondant est qu'un élément structurel ou est juste un arrêt mécanique pour garder le électronique en place? dernière i essayé de chercher cet objet Audi et tout ce qu'ils ont est le super noir brillant (4S0951532A) quelqu'un sait si une version de satin est disponible? de toute façon guide très intéressant en effet. Merci
  13. [Présentation] Tommyknocker, Good day everybody, I'm Tommaso from Italy, I'm sorry I don't speak any French but with the help of goggle and some similarities with Italian I can still enjoy this forum, already picked up some very interesting topics. Here's my car, TTS Mk III S-Tronic, picked up this august new, my second TT, previous was a Mk II. Now getting closer to 10k km. Few optionals on: White Ibis,Tech pack, B&O, full leather seats, Led lights, object pack, light pack, Locking wheel bolts, light rain sensor, Auto dimming rear view mirror, 19” x 9J "5-twin-spoke" Titanium for the summer and 19” x 9J "5-parallel-spoke Star" for winter. Bonne journée à tous, Je suis Tommaso d'Italie, je suis désolé, je ne parle pas français, mais avec l'aide de lunettes et quelques similitudes avec l'italien je peux encore profiter de ce forum, déjà ramassé des sujets très intéressants. Voici ma voiture, TTS Mk III S-Tronic, ramassé cette nouvelle août, mon deuxième TT, précédente était un Mk II. Maintenant, se rapprocher de 10k km. Peu d'options sur: Ibis blanc, Tech Pack, B & O, des sièges en cuir pleine, les lumières LED, meute objet, sac léger, verrouillage des boulons de roue, capteur de pluie, Rétroviseur anti rétroviseur, 19 "x 9J" 5 doubles branches " titane pour l'été et 19 "x 9J" 5 branches parallèles Star "pour l'hiver.
