sany98
Utilisateur Novice-
À propos de sany98
[Tuto] Online Services (Audi Connect, Google Earth & Trafic Online) en WIFI
sany98 a répondu à un(e) sujet de hsd92 dans MMI 2G - 3G - 3G Plus / GPS advanced
Ok, thank you! -
Never worked with Linux earlie so complete noob. So if use files from MMI-3GP-GE-WIFI-uninstall it won't work because I need files that were created during the installation? -
No, i have not saved the files and i seems that i have lost the sd card. is there any other way? -
Hi So I should use script to remove the patch then update and then reinstall the patch? -
Hi. I have this solution working on my 3gp+ 6.20.4 and fw 770 for some time. I would like to update to k900 but only if this works on k900. My car is an a6 4g. Skickat från min SM-G928F via Tapatalk -
I finally got Google Earth working. I have reinstalled the FW and maps and after reboot GE loads in about 2mins and works. I have also tried to activate Traffic data online, but it didn't worked. MMI pops up that there is one licence available to activate but when I try to activate, it always returns me to same screen (activate Traffic data). -
How long should I wait you think? I think that coverage is good, YouTube and everything else works normally when connected to MMI with my tablet. -
Hi I have reinstalled the GEMMI with the MMI fw update 783. Another problem is GE loading. It looks like GE is fully loaded but it doesn´t switch the maps. I have waited for at least 30 minutes but nothing happens. I believe it has something with GEEMI cache to do, maybe even with the partition. Can you please check how is that looking in your green menu? http://postimg.org/image/6qyvyc8nr/ http://postimg.org/image/sxj58cavp/ http://postimg.org/image/cik5yt78x/ -
Yes, I was using 3.10 and then upgraded to 3.18. I did factory reset before update. GE is activated in green menu, but it's grayed in map display option. When I change to GE, Google logo in right corner start loading but stops when G letter is loaded, rest of the letters are also grayed. The is a GE option in the green menu and when try to get GEMMI (Google Earth MMI) info or start GEMMI I get message GEMMI not installed. I believe that the problem is there. -
I have just checked and Audi Online also works. Skickat från min SM-G928F via Tapatalk -
Hi frankie I have updated rooter fw to 3.18 and it looks like it worked but google maps still don't work(Google Earth is still gray in Map Display option). I have checked the settings in green menu and everything is like in installation guide. Internet works on my laptop when i connect it with the MMI (wireless). Ping also works as you can see below. What have i done wrong? Diag v1.0 20151104_095606 - step 1 start at 20151104_095605 20151104_095613 - step 2 Display picture start 20151104_095613 - step 3 Success mmelauncher.cfg.bak exist 20151104_095613 - step 4 Success mmelauncher.cfg backuped on SDCARD 20151104_095613 - step 5 Success mme-becker.sh exist 20151104_095613 - step 6 Success resolv.conf exist 20151104_095613 - step 7 Success nws.cfg.bak exist 20151104_095613 - step 8 Success nws.cfg backuped on SDCARD 20151104_095613 - step 9 Success pf.conf.bak exist 20151104_095613 - step 10 Success pf.conf backuped on SDCARD 20151104_095613 - step 11 ifconfig uap0 uap0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500 address: 00:1c:d7:2e:47:ef media: <unknown type> autoselect inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255 inet alias 192.168.1.31 netmask 0xffffff00 broadcast 192.168.1.255 link 00:00:00:00:00:00 20151104_095614 - step 12 route show Routing tables Internet: Destination Gateway Flags default 192.168.1.254 UG 10.0.0.0/24 link#3 U 10.0.0.20 00:00:00:00:05:56 UHL 10.0.0.255 link#3 UHL localhost.localdom 127.0.0.1 UH 192.168.0.0/16 192.168.1.254 UG 192.168.1.0/24 link#5 U 192.168.1.1 00:1c:d7:2e:47:ef UHL 192.168.1.254 c4:e9:84:bc:ae:f2 UHL 239.255.255.250/32 192.168.1.1 UG 20151104_095615 - step 13 ping 192.168.1.1 PING 192.168.1.1 (192.168.1.1): 56 data bytes 64 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=255 time=0 ms ----192.168.1.1 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 0/0/0 ms variance = 0 ms^2 20151104_095619 - step 14 ping 192.168.1.254 PING 192.168.1.254 (192.168.1.254): 56 data bytes 64 bytes from 192.168.1.254: icmp_seq=0 ttl=64 time=2 ms 64 bytes from 192.168.1.254: icmp_seq=1 ttl=64 time=2 ms 64 bytes from 192.168.1.254: icmp_seq=2 ttl=64 time=2 ms 64 bytes from 192.168.1.254: icmp_seq=3 ttl=64 time=2 ms ----192.168.1.254 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 2/2/2 ms variance = 0 ms^2 20151104_095623 - step 15 ping www.google.fr PING www.google.fr (216.58.209.99): 56 data bytes 64 bytes from 216.58.209.99: icmp_seq=0 ttl=53 time=760 ms 64 bytes from 216.58.209.99: icmp_seq=1 ttl=53 time=57 ms 64 bytes from 216.58.209.99: icmp_seq=2 ttl=53 time=56 ms 64 bytes from 216.58.209.99: icmp_seq=3 ttl=53 time=516 ms ----www.google.fr PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 56/347/760 ms variance = 122868 ms^2 20151104_095632 - step 21 Success Display picture Done 20151104_095632 - step 22 Success -
Hi I'm also having problems to connect MMI with mr3020 and E3276. I have checked settings several times and went through the guide three times but it seams that MMI don't connect with router. Diag v1.0 20151103_141013 - step 1 start at 20151103_141012 20151103_141017 - step 2 Display picture start 20151103_141017 - step 3 Success mmelauncher.cfg.bak exist 20151103_141017 - step 4 Success mmelauncher.cfg backuped on SDCARD 20151103_141017 - step 5 Success mme-becker.sh exist 20151103_141017 - step 6 Success resolv.conf exist 20151103_141017 - step 7 Success nws.cfg.bak exist 20151103_141018 - step 8 Success nws.cfg backuped on SDCARD 20151103_141018 - step 9 Success pf.conf.bak exist 20151103_141018 - step 10 Success pf.conf backuped on SDCARD 20151103_141018 - step 11 ifconfig uap0 uap0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500 address: 00:1c:d7:2e:47:ef media: <unknown type> autoselect inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255 inet alias 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 link 00:00:00:00:00:00 20151103_141018 - step 12 route show Routing tables Internet: Destination Gateway Flags 0.0.0.0/8 link#5 U 10.0.0.0/24 link#3 U 10.0.0.20 00:00:00:00:05:56 UHL 10.0.0.255 link#3 UHL localhost.localdom 127.0.0.1 UH 192.168.1.0/24 link#5 U 192.168.1.1 00:1c:d7:2e:47:ef UHL 192.168.1.254 link#5 UHL 239.255.255.250/32 192.168.1.1 UG 20151103_141018 - step 13 ping 192.168.1.1 PING 192.168.1.1 (192.168.1.1): 56 data bytes 64 bytes from 192.168.1.1: icmp_seq=0 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=1 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=2 ttl=255 time=0 ms 64 bytes from 192.168.1.1: icmp_seq=3 ttl=255 time=0 ms ---- 192.168.1.1 PING Statistics---- 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 0/0/0 ms variance = 0 ms^2 20151103_141021 - step 14 ping 192.168.1.254 PING 192.168.1.254 (192.168.1.254): 56 data bytes ping: sendto: Host is down ----192.168.1.254 PING Statistics---- 4 packets transmitted, 0 packets received, 100% packet loss 20151103_141034 - step 15 ping www.google.fr ping: Cannot resolve "www.google.fr" (Host name lookup failure) 20151103_141040 - step 21 Success Display picture Done 20151103_141041 - step 22 Success -
Hello I have activated 6.20.4 maps using Carsons activator so my VIN is no longer shown in MMI. Can I use VINpatcher to manually input my VIN so I can activate Audi online service or there is other ways to do that? Skickat från min GT-I9506 via Tapatalk -
I want external antenna to have more stable connection, i can live with dongle attached to the router ;). So you mean that if the router supports openwrt, it will work with mmi? Skickat från min GT-I9506 via Tapatalk -
How about this one? http://www.aliexpress.com/item/GL-iNet-AR-150-AR9331-OPENWRT-Firmware-150Mbps-Routers-WiFi-Router-WiFi-Repeater-Booster-Extender-External/32480174084.html Skickat från min GT-I9506 via Tapatalk
